jet chip for a f-250 v10, do they help >
Old 10-03-2006 | 11:11 AM
BajaRunner's Avatar
Default jet chip for a f-250 v10, do they help
I found a guy that has a jet chip for my truck. i have the v-10, ive heard they help a lot with diesels but what about the gas trucks? its new, he bought the v10 and has a diesel and never returned it. he wants $175.
what are the pros and cons?
BajaRunner is offline
Old 10-03-2006 | 11:42 AM
DRIPPINWETII's Avatar
Default Re: jet chip for a f-250 v10, do they help
Save your money and buy a programmer. @ $300.00 You can set your rev limiter,speed,shifts,etc. Even has an E-Z program where it will set everything for you. You will need to set it for what grade of fuel you use. I have 1 for my 5.3L and I love it. Have to make sure you use the the correct fuel grade or will spark knock.
Also have the K&N filter kit.
DRIPPINWETII is offline
Old 10-03-2006 | 12:57 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Diablo Predator tuner is the tuner to buy. Much better than the HyperTech PowerProgrammer III. I don't know what it will do for your truck, but it might give you some options to play around with.
Sydwayz is offline
Old 10-03-2006 | 08:52 PM
I had the hypertech on my ford v10 dually and with the intake kit and exhaust it really woke the truck up. fuel picked up a little as well once I kept my foot out of it.
JPD Motorsports is offline
Old 10-04-2006 | 09:36 AM
I agree with jpd moto, I just switch my truck to the hypertech programmer, deleted my muffler. I was amazed by the unleash power that the truck had left in it.
orlando is offline
Old 10-04-2006 | 09:59 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Exhaust does help on that truck. CheckmateF1 here on OSO had the V10 in a CC SB dually. He did the exhaust and intake on his.
The Diablo Predator is a much better tuner than the Hypertech. It does everything that the Hypertech does and then some. Cap it off with the fact that it is also a code reader, and a diagnostic tool that you can leave plugged in while driving, and watch your computer/sensor values change; including checking how hard your engine is running while towing, as well as finding the best RPM for peak performance and peak mileage. I would leave my Diablo Predator plugged in when towing, and set it in the cupholder to know exactly what every sensor on my engine was doing. The Hypertech does not do that. I had both. I put the Hypertech in the garage and never touched it again.
Sydwayz is offline
chuckd1025
23
01-07-2008 02:15 PM
SkiDoc
14
12-06-2007 07:34 AM
tony manzella
0
09-02-2007 09:09 PM
Buddy OO
02-02-2004 03:37 PM
