Cockpit interior
Old 10-04-2006 | 02:28 PM
Default Cockpit interior
Does anyone know a good upholstery place? I am going t have the power play redone this winter and am looking for suggestions. Any idea of a ballpark of what I should look to spend???
Thanks!!
trader1 is offline
Old 10-04-2006 | 03:19 PM
Stormrider's Avatar
JC Performance Engines
Default Re: Cockpit interior
lakeluvr on the board has a shop.
Stormrider is offline
Old 10-04-2006 | 07:43 PM
AIR TIME's Avatar
talk to joker powerboats they have a real good guy doing there work
AIR TIME is offline
Old 10-04-2006 | 08:49 PM
Trader1 it will cost you 7k for cockpit only. Ft lauderdale, and also in NJ called AL'S he does the outerlimits. Why do you want to change it?
baja27 is offline
Old 10-04-2006 | 08:54 PM
Dave M's Avatar
Veteran: Navy
I think it's tough to compare prices with different boats. My boat has bolsters (2), side panels (2), rear seat base, rear seat back, and sunpad, very basic. Other boats I've seen have dozens of individual pieces. Then you start talking about colors, materials, etc.....
Dave M is offline
Old 10-04-2006 | 09:01 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
There is a guy down here in Richmond that does FANTASTIC work. He has done work for at least 3 OSO members with great results. 35' Cigarette/Cignificant,
42' Sonic/runnin gun, and 37' Active Thunder/excursion.
If you are interested, shoot a PM to 'excursion' aka James, and ask the number of the guy who did his sunpad. He fixed my cover after storm damage, so I can vouch for his work as well, I just don't have his contact info.
Sydwayz is offline
Old 10-04-2006 | 09:36 PM
Stormrider's Avatar
Joker uses PPI in florida, and i'm not sure they are doing much work for private individuals these days.
Old 10-05-2006 | 02:53 AM
Thanks!!
trader1, The original upholstery in your Powerplay was designed, built, and installed by "Custom Marine Upholstery" at the Powerplay facility in Ft. Lauderdale. I believe that Jeff & Bill have done "Most" of the PP's. If the Powerplay factory had a trade-in, or a customers boat needed the upholstery repaired, updated, or replaced, Jeff & Bill did the work! They also deal directly with Powerplay owners. They have ALL the patterns, including the triple back seat drop out bolster, they can modify your upholstery to fit your needs! Jeff & Bill have done work for me on my 38' PP. I highly recommend CMU to you for your Powerplay! You can call them @ 954-316-9818! If you have any questions, let me know I will try and answer them for you, Good Luck & Blue Skies, Robbie
Let me know how things work out!
DEFYN GRAVITY is offline
Old 10-05-2006 | 08:58 AM
Baja, I am going to have the boat repainted and change the interior colors. It is going to look bad a$$.
Thanks for all the help guys!!!
trader1 is offline
Old 10-05-2006 | 09:21 AM
cuda's Avatar
Last time I bought some seats from them, about three or more years ago, he said they were so busy making stuff for new boats that they weren't doing any private work. That may have changed since then. They do great work. Worth a call anyway.
cuda is offline
