speedmaster3 to bravo questions >
Old 10-05-2006 | 06:23 PM
sleepy_pirate's Avatar
Default speedmaster3 to bravo questions
does anyone know if the hole behind a speedmaster 3 and a bravo transom are the same or close? if i get rid of the ssm3 and install a bravo, will i need to fill in a hole or cut a bigger one??? hopefully it just bolts up in the same spot.....
thanks in advance for any help you guys can offer...
DT
sleepy_pirate is offline
Old 10-05-2006 | 06:27 PM
t500hps's Avatar
21 and 42 footers
Default Re: speedmaster3 to bravo questions
bravo hole is smaller.......can you say "new transom"?
t500hps is offline
Old 10-05-2006 | 08:27 PM
stellings used to make a trs to bravo extension box. not sure if the hole is the same, but it would be worth a call.
bobkatz is offline
Old 10-05-2006 | 08:48 PM
what about a ssm#3 to trs? are they the same?
Old 10-05-2006 | 08:59 PM
Reed Jensen's Avatar
Why are you going away from a SSM #3?
Reed Jensen is offline
Old 10-05-2006 | 09:04 PM
Lofty's Avatar
Stellings no longer makes those boxes but I think Randy has a few left over from the old days.
I'm with Reed. Why go from a good SSM III drive to a Brako? You could allways go to a Konrad.
Lofty is offline
Old 10-05-2006 | 09:07 PM
you guys want to buy the ssm#3? i got lots of goodies with it? i am just getting away from a big motor and dont really need the ssm#3 anymore. actually thought i had a buyer for it a day or two ago. got lots of props, service manuals, lots of gaskets, and a complete (i think) kit of tools to work on the ssm#3. whats it all worth as a package???
Old 10-05-2006 | 09:30 PM
IRONMAN's Avatar
I have done a similar swap sucessfully with great results check your PM
IRONMAN is offline
Old 10-07-2006 | 03:17 AM
Donzi502's Avatar
We just did a change from Volvo drives to Bravo Diesel. We had to close the hole down and is was not a problem. Just used two layers of ply and rebated it in and glassed over then cut a new hole. Easy really.
Donzi502 is offline
Old 10-07-2006 | 09:20 AM
Stillens tech guy told me they sold the transom adapters to some speed shop in FLa(dont remember the name, sorry) and I talked to the guy. he says they have extention boxes in stock to go from ssm and trs transoms to bravo. wont even have to get out the duct tape for this project.. now if i could only remember where these bolts went it might start!
