E-mail Help
Old 10-17-2006 | 12:01 AM
Chuck's Avatar
Default E-mail Help
I am trying to retreive some old e-mails, both sent and received. I never deleted the e-mails, but after 27 days they drop off my system. The e-mails are on an AOL acct. AOL tells me that they are gone forever and unable to be retreived. They must be on the hardrive right? How can I pull them up and print them???
Chuck is offline
Old 10-17-2006 | 12:07 AM
Default Re: E-mail Help
Unless you saved them somewhere, they're gone.
Griff is offline
Old 10-17-2006 | 12:17 AM
Chuck's Avatar
I thought that nothing is gone forever on a computer.
Chuck is offline
Old 10-17-2006 | 12:29 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Depends on how you have your AOL setup. There is a configurable setting to save emails to "Your Computer." If you don't have it setup in this fashion, they are gone.
Sydwayz is offline
Old 10-17-2006 | 08:29 AM
Chuck's Avatar
How would I check that setting? Thanks
Chuck is offline
Old 10-17-2006 | 08:40 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Its in your Mail Settings.
Easiest way to see what you may/may not have is:
Sign into AOL.
Open your Mailbox Application
There are several tabs across the top:
NEW / OLD / SENT / MANAGE MAIL / SEARCH MAIL
Go to the MANAGE MAIL tab.
There should be a folder for SAVED ON MY PC.
Inside of that, there are 3 folders: Incoming/Saved...Mail Waiting To Be Sent...Mail You've Sent
If its not in one of those folders, its gone.
To fix the setting for future so it does save everything.
Go into AOL. Type MAIL SETTINGS into the search bar at the top center. This will pop up a results page. Click on the first listing, and this will pop up your Mail Settings for AOL. You can tweak what you need in there. Good luck.
Sydwayz is offline
Wild
Cigarette
16
02-04-2008 05:14 PM
Steve 1
01-07-2003 05:04 PM
FunHome
Velocity
1
01-05-2003 08:28 AM
ssherman
04-02-2002 07:39 PM
