msd starter saver >
msd starter saver
msd starter saver
Old 10-17-2006 | 09:41 AM
Default msd starter saver
I have a msd dist #83606 a msd 6m-2 soft touch 8768 the dist. are locked out thinking on installing a msd starter saver on each eng. has anybody used them and would they use them again
eliminatethis is offline
Old 10-17-2006 | 10:37 AM
PatriYacht's Avatar
Default Re: msd starter saver
I have been running them on 540's with locked timing. Yes I would use them again. Last year I ruined about 6 starters, this year none.
PatriYacht is offline
Old 10-17-2006 | 10:55 AM
that's what i needed to here thank's
Old 10-17-2006 | 11:21 AM
What problem do they resolve and how?
RBeyer is offline
Old 10-17-2006 | 11:55 AM
They retard the timing 10 or 20 deg. on startup till 800 rpm and if the eng. drops below 500 rpm the retard again
Old 10-17-2006 | 01:21 PM
PatriYacht's Avatar
The engines would kick back and destroy the gear drives in those little starters. I set them for 20 degrees retard and the engines turn over like stockers.
Old 10-17-2006 | 02:54 PM
Ian,
What is the advantage of this MSD retard system vs. using the standard MSD non-lock out method with the springs?
Sprague
BenPerfected is offline
Old 10-17-2006 | 03:40 PM
PatriYacht's Avatar
They idle better with the locked timing. Not much but better.
Old 10-17-2006 | 03:46 PM
patriyacht how long have you been in waterford I grew up on williams lake class of 78
Old 10-17-2006 | 03:53 PM
I run almost all my engines locked out on timing and have never had a starter problem whether Supercharged or N/A. Over time the weights and spring assemblies get rusted and stick and I have even seen springs break.
mrhorsepower1 is offline
