20" wheels on superduty
Old 10-18-2006 | 01:01 AM
Default 20" wheels on superduty
Im considering a set of 20" rims for my superduty and wanted to know what size width and backspacing I should get..
I am going to eventually put a leveling kit on it but want to be able to run 35" tires with no rub. But i dont want a wheel that juts out 8 inches from the wheel well and what width do you guys reccomend?
waterboy222 is offline
Old 10-18-2006 | 06:29 AM
mama tryed's Avatar
Default Re: 20" wheels on superduty
Shoot a PM to Buck183,, he's the master - bater
mama tryed is offline
Old 10-18-2006 | 07:47 AM
Registered User
A large percentage of aftermarket wheels don't meet the load rating of the stock Superduty wheel. Some are as much as 1,000#+ short. No problem if you don't ever tow or haul but if you do, you can break one of those cast wheels in an instant. Tire selection in load-range "E" in 20" is pretty thin too.
Chris Sunkin is offline
Old 10-18-2006 | 07:57 AM
berns29scarab's Avatar
here's mine its a 99 f-250 4x4 powerstroke these are 305-50 20's. had slight rub on the flares on the backside of the wheel well. priced the leveling kit but decided to go with the fabtec 5.5" lift kit instead. got the kit for $1850.00 installed NEW FRNT SPRINGS AND FRNT AND REAR SHOCKS ALL INCLUDED
Attached Thumbnails 20" wheels on superduty-dscn8069.jpg   20" wheels on superduty-dscn7949.jpg   20" wheels on superduty-dscn7950.jpg
berns29scarab is offline
Old 10-18-2006 | 07:58 AM
tires are nitto grapplers
Old 10-18-2006 | 08:16 AM
mwdill's Avatar
i went with 18's , more E load range tires in that size, but as far as back spacing 4 1/2 to 5 inch with 35's and no rub.
mwdill is offline
Old 10-18-2006 | 08:26 AM
Sean H's Avatar
A to Z
20's are a factory option, find out what the specs are of those.....
Sean H is offline
Old 12-25-2006 | 11:39 AM
My 05 and 07 Harley Edition Super Duty came stock with 20" wheels. The only issue I had was replacement tires with load E rating. As far as I know only Goodyear makes a replacement tire. But if anyone else knows of another option please enlighten me.
1bagger is offline
Old 12-25-2006 | 12:12 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
BFGoodrich All Terrain KO, 20", Load Range E (GREAT tire)
http://www.bfgoodrichtires.com/specs...t-a-ko/44.html
Nitto Tires Dune Grappler 20", Load Range E
(Click on sizes and specs)
http://www.nittotire.com/tires_dunegrappler.asp
Nitto Tires Terra Grappler 20", Load Range E
http://www.nittotire.com/tires_terragrappler.asp
Docmanrich37 is running Nitto TG Load Range E/20" on his GM.
Sydwayz is offline
Old 12-25-2006 | 02:05 PM
have goodyear wrangler at/s stock on the 20" ford option, great tires so far
Buddy OO is offline
