Sealer?
well , you should not get runs if applied properly , just sealing , not building like primer.
if you get little smalll dust nibs , don't sweat it , just base/clear over and those flaws dissapear if you sand/polish..
you can however tack it off with a tack cloth if it is not a wet on wet sealer. touch the paper first to make sure sealer is not still tacky.
not real familiar with that brand , i'm a sikken's / ppg painter..
Originally Posted by 24degrees
I'm painting my car and I plan to seal it right before painting.
My question is what do I do if I get some dirt in or run the sealer?.......we are using Standox.
Thanks.
Thanks.
