Bravo 1 X leak - thoughts? >
Old 10-22-2006 | 11:23 AM
BryanTuvell's Avatar
Donzi33ZX
Default Bravo 1 X leak - thoughts?
I had my drives pulled, flushed and engine alignment check last winter. Boat was only used a hand full of times in 06, about 15 hours.
I have been overseas the last few months and returned this weekend to find a small seepage/leak from the center stud on the drive. My mechanic is off on Sunday so what do you drive guys think?
Could it just be loose?
Thanks, Bryan
BryanTuvell is offline
Old 10-22-2006 | 06:25 PM
Vinny P's Avatar
I hate the winter!!
Default Re: Bravo 1 X leak - thoughts?
Most likely the seal behind the cap is leaking. See attched link, part #2..
http://www.mercruiserparts.com/Show_...ift+Components
Vinny P is offline
Old 10-22-2006 | 06:41 PM
Mr Gadgets's Avatar
Charter Member #601
Bryan,
If the cap is not torqued down evenly, it can sit funny, top to bottom.. but the main thing is the seal behind the cap. Right above that bolt is the detent for the shift lever, which will put pressure on the lower cap. I would slightly loosen all the bolts.. and then retorque them.. Careful the drive lube is in the upper portion of the cap. Then clean it with Mineral spirits and see if it leaks again.. Next oil change pull the cap and clean it and check the gasket.. it is similar to an oring, but different shape..
Hope this helps..
Dick
Mr Gadgets is offline
Old 10-23-2006 | 03:47 PM
Donzi33ZX
Dick, that is great data.
I love this website!
Thanks again, Bryan
brwn234
Drives and Lower Units
1
07-13-2008 09:53 PM
xhere
8
01-29-2006 10:23 PM
MetraMan
6
07-02-2005 01:29 PM
Dock Rat
12
05-11-2005 09:56 PM
Ran-Dom 32
4
07-08-2003 09:26 AM
