Flooded boats
Old 10-22-2006 | 11:32 AM
Default Flooded boats
Hey guys i need your opionions. My husband is thinking about buying a boat that sunk during Katrina. what are your thoughts on flood damaged boats (under water for 2 hours)? besides rebuilding the engines, new material on the seats and cabin, replacing gauges, ect. what are the risk of buying a flooded boat. is mold really a big problem? dont all boats have some mold? he can buy the boat really cheap.
thanks,
pamela
pam_k is offline
Old 10-22-2006 | 11:42 AM
bouyhunter's Avatar
Default Re: Flooded boats
Only under water for two hours??
I doubt it, but if only under for two hours, I wouldn't think it would be too bad.
If you're already planning on doing a full re-rig - knock yourself out.
I would be suspect of all wiring and plumbing, and make sure the stringer system and Transom are dry.
The hull itself, it should be fine IMO.
Good luck.
bouyhunter is offline
Old 10-22-2006 | 11:46 AM
ratman's Avatar
what kind of a boat are you looking at?
ratman is offline
Old 10-22-2006 | 12:13 PM
bouyhunter's Avatar
Rat - how long was your tub under??
Are you getting that babe back together?? Haven't seen any pic's in awhile.
Or did you get yourself all wrapped up in Duct tape and super glue that you couldn't reach the camera?
Old 10-22-2006 | 12:16 PM
30 something cafe?
pam_k is offline
Old 10-22-2006 | 12:43 PM
ratman's Avatar
i'll have it primer in a few more days.
ratman is offline
Old 10-22-2006 | 12:46 PM
ratman's Avatar
Originally Posted by pam_k
30 something cafe?
were ALL of the gauges and electrical components replaced? have you had it surveyed?
ratman is offline
Old 10-22-2006 | 12:48 PM
ratman's Avatar
make sure the surveyor has a moisture meter.
ratman is offline
Old 10-22-2006 | 01:05 PM
nothing done to it yet except cabin bed and couches taken out to dry out. no survey but thats a good idea. thanks.
pam_k is offline
Old 10-22-2006 | 02:24 PM
Jassman's Avatar
Get a good survey, not some fly by night. Make sure the stringer system is ok. All cosmetic stuff can easily be replaced. It's winter where you're at so this would make a good project for you guys, and like you said if it can be picked up cheap, and it gets you safely out on the water, that's the bottom line. Hope it works out for ya all. Jeff
Jassman is offline
