Engine Hatch 36 OL
I was wondering if anyone has had the screw drive go bad on there hatch? Mine just decided to stop working. I hear the motor spinning but I have to pull it up at the same time to get it open. And the engine cover is freaking heavy. Is this an easy fix?
Changed it again last winter.
They are very standard, just make sure you get a 24 inch stroke. Unhook it at the top of the hatch and lift the hatch up and block it with a couple of 2 x 4's. Then clip the wires off your old actuator and remove the bottom bolt. Then just reverse the process installing the new one and use crimp wire connectors with the heat shrinks for your connections.
You can get the actuators at the following places:
Trick Marine
CP Performance
Eddie Marine
Rex Marine
I got a fully polished unit and it was around $250.00 if memory serves me right.
Let me know if you have any questions or problems.
And YES those hatches are heavy!
http://www.trickmarine.net/productde...d=697&incat=35
Here is the link to the one I bought. It looks GREAT and works much faster then the stock unit. Plus it really gets the hatch up high.
Tell Fred at Trick that Dock Holiday sent you for a FREE shirt!
what are you doing to my boat?????!!!!!!!!!!!
just kidding,
scott pm your address and i will send out the v-berth cover and the gps manual. the black full cover you have i bought from doc. small world huh?
just kidding,
It is a small world. My wife and I love the boat. Doc, thats the one I ordered and Trick said he would send me a free shirt since you referred me. Haha. Yea Scott after I saw Docs boat I thought I would start the detail process and try to compete. But the old actuator started slipping so a new ones on the way. Your boats in good hands, promise. I'll PM you.
