500efi rebuilds >
500efi rebuilds
500efi rebuilds
Old 10-25-2006 | 09:23 PM
berns29scarab's Avatar
Default 500efi rebuilds
looking at a boat with 500efi's and just hit 400 hrs and have never been opened up. oil has been changed every 35-40 hrs with reciepts to prove. whats recommended at this point.
berns29scarab is offline
Old 10-26-2006 | 06:25 AM
Canada Jeff's Avatar
Default Re: 500efi rebuilds
Rebuild her to 600 hp :-)
Canada Jeff is offline
Old 10-26-2006 | 08:18 AM
Minimum would be springs but with the life these 500HP style engines have you are best to pop the heads off and check out the valves and redo the valve seats. As time wears on the springs on these engines get weak and this allows the valve to bounce on the seat when it closes. This hammers the seat and you will see a power loss.
Its not a bad idea to put in a new set of lifters at this point.
Chris
cstraub is offline
Old 10-26-2006 | 08:20 AM
pkspx's Avatar
Call Dean Gellner 216.398.8500
IMO probably need a leak down test first and see how she is holding up. Seriously though, if your looking to rebuild, call Dean.
pkspx is offline
Old 10-26-2006 | 11:17 PM
he did a mechanical survey on it about 20 hrs ago...
Leak down %'s are as follows
Port engine cyl- 1=13% 3=9% 5=4% 7=5% 2=12% 4=10% 6=12% 8=9%
Stbd engine cyl- 1=9% 3=4% 5=12% 7=30% 2=8% 4=4% 6=29% 8=10%
Old 10-27-2006 | 06:39 AM
Whats nice about the efi's is you can get a print out of the engine's history from the computer. How many hours at what rpm. Knock run time, if any. Loads of info. I would ask for one of these for each engine.
Old 10-27-2006 | 08:20 AM
BillR's Avatar
OSO Moderator
Personally, I'd drop the boat off at Joey Griffin's in Washington, NC on your way home. Let him rebuild them and add some HP if you want. Joey is about as straightforward and honest as they come and his prices are more than reasonable.
Plus, if you need any work done on the boat (paint, FG, rigging) he can have it done in his shop. (they do it all there) Plus the boat is stored indoors while the motors are being done. Do a search on OSO for Joey Griffin - nothing but GOOD things are said about him.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 10-27-2006 | 11:19 AM
Here is a copy of a report I had printed out on my hp500efi a couple years ago. I was trying to sell it so I thought I should have this ready.
Attached Thumbnails 500efi rebuilds-scan10028-oso.jpg   500efi rebuilds-scan10029-oso.jpg
White Knuckles
Sutphen
10
01-22-2008 09:45 PM
SED70
08-06-2006 07:48 PM
nordic95
11-24-2005 09:32 PM
26sonic
1
02-18-2005 07:01 PM
INCOGNITO
6
01-25-2003 12:28 PM
