Just a quick two thumbs up !! >
Old 10-26-2006 | 02:42 PM
berns29scarab's Avatar
Default Just a quick two thumbs up !!
Had multiple conversations today with one of the most helpful gentlemen i've dealt with in the marine industry. His name is Mark and he owns and operates MER Performance Marine Services down in South Carolina. Took as much time as my dumbassss needed to explain things to me and give me both best and worst case scenarios. Mark just a quick thanks for your patience. If ya dont want to take my word for it feel free to contact him yourself
Marc 843-399-8785
berns29scarab is offline
Old 10-26-2006 | 02:50 PM
Offshoreonly Advertiser
Default Re: Just a quick two thumbs up !!
A good reason for having caller ID,just wait until he meets you.
sy goldberg is offline
Old 10-26-2006 | 05:19 PM
Strip Poker 388's Avatar
Rob
Marc 843-399-8785
What did he say about the hours?
Strip Poker 388 is offline
Old 10-26-2006 | 05:22 PM
Mark is super to deal with.
cstraub is offline
Old 10-26-2006 | 05:33 PM
he did a mechanical survey on it about 20 hrs ago...
Leak down %'s are as follows
Port engine cyl- 1=13% 3=9% 5=4% 7=5% 2=12% 4=10% 6=12% 8=9%
Stbd engine cyl- 1=9% 3=4% 5=12% 7=30% 2=8% 4=4% 6=29% 8=10%
Old 10-26-2006 | 05:36 PM
Rob
Stbd motor 30% if thats based off 100psi is pretty high,.did he think it was rings or valves?
Old 10-26-2006 | 05:37 PM
somethings happening on #6 and #7 on stbd engines, the engines were NOT hot when this was done...engines were run for approx 5 mins then this test was performed...unsure if its a valve issue or what
Old 10-26-2006 | 05:39 PM
they potential buyer ran away once he saw the results so MArc never went any further to determine if it was leaking thru exhaust, intake, manifold etc...nor did he do a compression test.
Old 10-26-2006 | 05:47 PM
Rob
5 min should be enough to get a little temp in it,unless the motor had been sitting a while and had rust on the seats,
Have they reajusted the price figuring you will have to freshen the motors,I would do both!!!
Old 10-26-2006 | 05:49 PM
thats a matter of opinion i guess...lol
