Water in oil
Old 10-30-2006 | 11:09 AM
Default Water in oil
have a 30ft Scarab w/twin 502s. Lost RPM on port side, told I hit something...after much srambling, found upper & lower units. Installed, still didnt solve problem. had boat hauled...told trans. shot. had port trans rebuilt, starboard trans freshened. Finally ran the boat..starboard water pump let go. Had impeller replaced. ran boat again. Now, find water in the port motor! What gives? Can water get in oil during install if motor is turned? Any info would be appreciated. Thanks, Tom
muffin is offline
Old 10-30-2006 | 11:32 AM
BY U BOY's Avatar
Default Re: Water in oil
Did The Engine Over Heat? How Much Water In The Oil?
Could Be A Blown Head Gasket Of Manifold Gasket.
BY U BOY is offline
Old 10-30-2006 | 01:06 PM
Water in the port motor has nothing to do with anything else you described unless when you lost the water pump, you overheated and blew a head gasket.
Griff is online now
Old 11-01-2006 | 08:56 AM
I never over heated the engine...the guy who rebuit the trans had it running. Water is to the top of dipstick.
muffin is offline
Old 11-01-2006 | 09:10 AM
10x's Avatar
10x
10x
It's possible that you've got a leaking engine oil cooler. That's the only way you'll get that much water in the oil. If the cooler starts leaking water, the only place it can go is into the oil, which eventually ends up back into your engine.
Pull the oil cooler and pressure test it to be sure.
Fountain powerboats rule "The Preacher"
Chicago Powerboat Club Director
[email protected]
www.chicagopowerboat.com
10x is offline
Old 11-01-2006 | 12:06 PM
I really hope you drained the water/oil mix out
If not, its probably gonna need a rebuild.
Griff is online now
Old 11-01-2006 | 01:10 PM
StraightJacket's Avatar
I agree with 10 x . where are you at maybe some of us can help you if needed
StraightJacket is offline
Old 11-01-2006 | 05:25 PM
Panther's Avatar
Frank's Marine Service
Check the intake manifold and gaskets. Also, check the exhaust manifolds. Sounds like a lot of water igot in the motor.
Panther is offline
Old 11-02-2006 | 06:50 AM
Thanks for all the tips...I had the oil changed...stored the boat untill next spring. Im in the Great lakes. Cold up here!
muffin is offline
Old 11-02-2006 | 09:30 AM
BY U BOY's Avatar
If You Had As Much Water As You Say You Did. You Really Need To Pull The Engine And Do Something To Prevent Rust So You Can Use It Next Season.
Just My .02
BY U BOY is offline
