Drive Showers for XR sportmaster
Does anyone know if there is available showers for the XR short sportmasters if you have removed the cavitation plate.
We removed the plate to allow room for a larger diameter prop. I could put the plate back on, but the clearance for the prop is almost nothing.
I believe most of the showers out there are engineered to have the pickups attached to the cavitation plate, so it presents a problem when you remove them.
Get your water suppy from a different spot. maybe an offshore pickup and then dump it on top of the drive???
