Upgrades to 502 MPI's >
Old 11-02-2006 | 08:54 PM
dean51267's Avatar
Default Upgrades to 502 MPI's
looking to see what is out there that can be done without degrading reliability..... thanks!
dean51267 is offline
Old 11-02-2006 | 09:06 PM
Registered User
Default Re: Upgrades to 502 MPI's
What are you looking to do? How much do you want to spend? There is a lot that you can do with the pieces in that motor, as they are GM's best stuff, The main restriction on the motor is the stock intake if you choose to leave the motor with its stock efi, unless you put a blower on it. New head gaskets, one whipple and mild boost, and you have just gainned 200+ HorsePower.
the duke is offline
Old 11-02-2006 | 09:13 PM
Ted G's Avatar
Here ya go, one of the best.
http://www.crockettmarineengines.com/products.html
Just wait till he finishes up jousting with the Duke boyz in Destin before you send the motors over
www.cbpba.com
Ted G is offline
Old 11-03-2006 | 05:15 AM
mats's Avatar
What hp increase will the crockett upgrade yield on a 502 MPI?
mats is offline
Old 11-03-2006 | 07:57 AM
Ted G's Avatar
He told me about 100 hp. Basically brings them to between 500 and 525. which frankly is about all you can ask of a stock Bravo anyhow.
www.cbpba.com
Ted G is offline
Old 11-03-2006 | 09:44 AM
satisfactionII's Avatar
And the cost of this HP gain is ?
satisfactionII is offline
Old 11-03-2006 | 11:05 AM
Registered User
Site says $6850 plus R&R motor, so in the $7500 range.
the duke is offline
Old 11-03-2006 | 07:28 PM
Lickitysplit's Avatar
Registered User
I'm having Derebery Performance Marine rebuild my 502's. Around 500 reliable horsepower. Stock Bravo 1's. Prices are a little above those above.
Bore 0.030" over
Replace ECU
Port and polish the heads, oversize inconel exhaust valves and SS intake valves
New cam
New crane hardware on the head, rockers, springs etc
Aeromotive fuel pump and pressure regulator
First class people and operation. Call Matt: 903-786-3797
Mike
Lickitysplit is offline
Old 11-03-2006 | 09:04 PM
Bore 0.030" over
Replace ECU
New cam
Mike
What are the cam specs? What exhaust system do you use?
Smarty is offline
Old 11-04-2006 | 12:24 PM
Registered User
Smarty, I have no idea yet. We've discussed using the same cam spec'd in the HP 500. I'm headed back up to Texoma next weekend to check on progress. I'll get the details.
I installed Stainless Marine exhaust a couple of years ago. We're going back with that set up.
Mike
