problems with 500efi
Subscribei recenmtly had a 500 efi rebuilt problem supposedly was that engine took in water thru the exhausts. rusted and broken valve. now engine stalls at low speed and runs rough. any ideas
Griff
close
- Join DateOct 2000
- LocationOmaha/LOTO
Liked:2,523 Times in 1,259 Posts
Valve adjustment too tight, timing, IAC ?????
Quote:
I would start by checking the base timing and that the Iac is opening and working properly. You did fix the water problem??
