496 belt
Old 11-07-2006 | 07:55 AM
Shooter's Avatar
Charter Member #300
Default 496 belt
kinda noob question but 1st engine with a serpentine belt and no manual. How do you measure the correct tension on a serpentine belt on the 496HO? Friend said you should be able to twist it 90 degrees no more? I put a new belt on and had to adust the alternator bolt all the way in. Is there another adjusting bolt?
Thanx!
Shooter is offline
Old 11-07-2006 | 01:08 PM
Strip Poker 388's Avatar
Rob
Default Re: 496 belt
you sure you have the right belt? I know on the 500's theres a idler pully that ajust the tension
Strip Poker 388 is offline
Old 11-07-2006 | 06:44 PM
Shooter's Avatar
Charter Member #300
yep
Shooter is offline
Old 11-09-2006 | 03:53 PM
Reckless32's Avatar
Rough Seas Lie Ahead
Merc maintenance manual says if by hand at the longest section between two pulleys (basically the top)
"...belt deflection by applying moderate downward pressure on belt. Proper deflection is approximately 1/4 inch (6mm).
Basically, if you've ever done one on a car you simply do the same thing.
Reckless32 is offline
Old 11-09-2006 | 08:55 PM
that is the only adjuster bolt and what you have is normal
phil0460 is offline
fountain27ho496
07-15-2008 09:35 AM
fountain27ho496
0
07-13-2008 10:14 AM
JohnnyG
2
07-06-2007 12:54 AM
bozsage
2
06-12-2007 06:58 PM
Frequency
9
06-16-2002 08:45 AM
