Bravo XR
I just rebuilt my Mercury Racing 500 efi. It's now a 540ci, 675HP, 699 ft lb of tourque engine. I'm pretty sure this set up will eat up my existing Bravo 1. It's in a Formula 271 fastech. Do any of you have an opinion about the ability of a new XR to handle this power?
With 650 HP Per side I would eat up Bravos left and right all the time,my boat is very light and I still had problems even when I would baby the boat.I installed Imco Extereme SC Drives and have not had another problem since Good luck.
skip the XR....much better alternatives out there. i kinda have a thing for formulas with arnesons....thats the way i would go....single or twin motor.
A little expensive considering the XR will last as long as your easy on the throttles and aren't running 3-4 footers at speed. If you can afford it, run the bravo until it grenades, then replace it with an XR. (otherwise just do it now and sell the the braov or keep it as a spare)
Mickey's running 900hp in a 26 American Offshore - baby's it out of the hole - but runs it flat out quiet a bit. Never had an issue with the XR - but it finally tore the stock transom assembly all to hell. $2500 later for a outdated assembly (new) and ALL is Well!!
It's in a 27 foot Formula fastech. Single engine. A few years back I put an XZ gear package and a billit top cap on my 1998 Bravo 1. I babied the drive last season and it held together with the 675 HP. (It was a 35 hour season) short due to a new baby at home. Based on your responses I have a few more questions:
1 - How much is an Imco extereme SC and would it bolt on to the existing set up?
2 - I'm hearing mixed reviews on the XR. Would I need to really baby it or just take it easy out of the hole.
