bad main bearing >
bad main bearing
bad main bearing
Old 11-07-2006 | 07:01 PM
Dtile's Avatar
Default bad main bearing
I m no machinst...took my block to machine shop, they state main bearing went along with piston, 22 degree clearance on main. My mechinic states its impossible looking at picture that it went, and clearence should be diagnosed with main caps on and torqued - which machine shop measured with cap and bearing off...who to believe. Engine had 10min run time...detonation due to leaking intake...This bearing look bad is what im asking. Thanks for the input, pardon the english.
Dtile is offline
Old 11-07-2006 | 09:11 PM
Donzi502's Avatar
Default Re: bad main bearing
Is this english or spanish? Not sure what you are asking here dude?
Donzi502 is offline
Old 11-07-2006 | 09:31 PM
Crazyhorse's Avatar
That bearing definitely doesn't appear to be wiped out. It didn't spin either. It doesn't look great but it's not toasted.
Bearing clearance is measured with the bearing installed and the cap bolts torqued.
Crazyhorse is offline
Old 11-07-2006 | 09:40 PM
Dtile's Avatar
Thanks Crazy...I think Jasper is killing these local shops and they want to add work to jobs that really dont need it. Thanks for the confirmation.
Dtile is offline
Old 11-07-2006 | 10:45 PM
Strip Poker 388's Avatar
Rob
Doesent look that bad ,not brased out, alittle trash in the babbit.Did its job asorbed it.
You # on clearence ?? is it .022 or .22 if its.022 that is a little tight. I bet money its not .22. if its .022 its the engine builders fault!!!! Oil presure?
What does the pistion look like?
Strip Poker 388 is offline
Old 11-07-2006 | 10:46 PM
HotPursuit's Avatar
I agree also clearance is checked with a dial bore gage and reads in thousands of an inch.
HotPursuit is offline
Old 11-07-2006 | 10:48 PM
Rob
http://www.offshoreonly.com/forums/s...hlight=bearing
Old 11-07-2006 | 10:50 PM
Rob
here picks
http://www.engineparts.com/Motorhead...gfailures.htm#
Old 11-07-2006 | 10:59 PM
Rob
Also if it leaned out/detinated it would beat out [wear]the top of the rod bearing. look at the upperbearing that the pistion is hurt.
heres a thread with some bearing picks ,last ones have 118 hours with .0027 to .0034 mains,Just took them out last week and was showing some wear
http://www.offshoreonly.com/forums/s...t=500efi+build
Old 11-07-2006 | 11:13 PM
Dtile's Avatar
Although he wants to replace all pistons, im just going to do the one that is bad. He was able to hone the wall ok...I think ill replace all rod bearings though. And reading Raylor's post about the new main bearings they are making with a special coating might not be a bad investment.
Dtile is offline
