Barry Grant Carbs!
Old 11-07-2006 | 07:35 PM
Default Barry Grant Carbs!
Barry Grant 650 CFM Mighty Demon Marine Carburetor
Barry Grant 750 CFM Mighty Demon Marine Carburetor
Check out are entire selection of Mighty Demons here!
Mighty Marine Demon is ideal for marine enthusiasts needing a carburetor to handle their needs for engine upgrades, or re-powers, while still maintaining the USCG standards for marine carburetors. The Mighty Marine Demons feature many of the same features that make the Mighty Demons great automotive carburetors. Designed for engines with cam profiles up to 260 degrees duration at 0.050“. They offer great throttle response, easy tuning, great fuel economy, and idle quality as well as top end performance. This will give you exceptional overall performance whether you're traveling at idle speed through a no wake zone or on a wide open throttle top end run. They are available in both naturally aspirated, and blower calibrated carburetors.
The Barry Grant Mighty Marine Demons are designed to meet/exceed all U.S.C.G. guidelines for marine carburetors
tpmarine.com is offline
Old 11-07-2006 | 07:42 PM
Default Re: Barry Grant Carbs!
Looking for something a little bigger...
Barry Grant 1090 CFM King Demon Marine Carburetor
Barry Grant 1090 CFM King Demon Marine Carburetor w/Annular Booster
Barry Grant 1190 CFM King Demon Marine Carburetor w/Annular Boosters
King Demon Marine Carburetors are ideal for marine enthusiasts needing a carburetor to handle their needs for engine upgrades, or re-powers while still maintaining the USCG standards for marine carburetors. The King Demon Marines feature many of the same features that make the King Demons the most powerful automotive carburetors. They offer great throttle response, easy tuning, great fuel economy, and idle quality as well as top end performance. This will give you great overall performance whether you're traveling at idle speed through a no wake zone or at wide open throttle on a Poker Run.
The Barry Grant King Demon Marine carburetors are designed to meet/exceed all U.S.C.G. guidelines for marine carburetors.
Old 11-11-2006 | 09:29 PM
blown formula's Avatar
Looking for 950cfm's???? Not in your list. Are they avail?
blown formula is offline
Old 11-13-2006 | 08:56 AM
Hi,
They offer a 995 King Demon RS in a Marine set-up. Part # 9627020GM, but they are not cheap...$1,199.00
Thanks!
Old 11-13-2006 | 09:13 AM
Barry Grant Blower Carbs...575 cfm thru 1190 cfm
Starting at $699.00
Check out all of your options here!!!
Old 11-13-2006 | 09:24 AM
Barry Grant "Blow Thru" Carbs...for those twin turbo set-ups...
Click here for applications & options!!!
Old 12-11-2006 | 07:05 PM
I also stock a full line of replacement parts for Demon Carbs.
So if you need rebuild kits, floats, jets, needle & seat assembly, power valves or anything else to do with your Barry Grant Demon Carb, give me a call, chances are I have it in-stock...
Old 03-15-2007 | 09:15 AM
Triad Performance is now stocking the entire Barry Grant product line...automotive and marine.
Do you need an alcohol oval track carb, or 2 marine 750's for your 8-71 Blower...we have them
We also stock the BG fuel systems fuel pumps & regulators, as well as the rush filters & nitrous works kits...
You can check out the entire product line at www.barrygrant.com or you can give us a call if you have any questions.
Old 04-20-2007 | 08:50 AM
Here's how each carburetor is tested before they ship.
[YOUTUBE]http://www.youtube.com/watch?v=XREjAZpf1kE[/YOUTUBE]
RumRunner is offline
Old 04-20-2007 | 09:55 AM
RumRunner,
Thanks for taking the time to share the video...it is just another example of the time and effort that goes into each Barry Grant Demon Carb...
