502 head bolts? >
502 head bolts?
502 head bolts?
Old 11-10-2006 | 03:51 PM
Default 502 head bolts?
Anyone know the part number and make for a set of cylinder head bolts for a gen6 502 with cast iron heads , arp does not list them. Thanks
alecsammy is offline
Old 11-10-2006 | 09:00 PM
Default Re: 502 head bolts?
Sammy,
I hope my memory isn't failing me, but I put together 2 Gen6 502's around the start of this year and I am almost certain we just used the FelPro "normal" big block head bolts. They were GM 502 short blocks with GMPP 502 cast iron heads. The ARP bolts for "oem cast iron heads" should work fine. 135-3601 for hex head and 135-3701 for 12 point. I can check on Monday in my computer system at the shop to be certain. I can look at the invoice for those engines. If I happen to by near the shop Sat, I will check for you.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
BillK is offline
Old 11-11-2006 | 03:51 AM
BillK's number looks correct to me also. It only list up to a 454 on the "application" but the bolts should be the same for a 502.
http://store.summitracing.com/partde...5&autoview=sku
Griff is offline
Old 11-11-2006 | 02:09 PM
Registered User
135.3601 is the correct ARP bolt for a 502. When you get them, if you compare them to a "stock" set that came on the Merc motor, you will have 3 different length bolts from ARP, and only 2 from Merc. The middle size ARP bolts go in the 2 lower corners inside the head
the duke is offline
Old 11-11-2006 | 02:32 PM
I was told that the 135-3706 were the bolts to use for a Gen VI 502 with stock cast heads and have them on order so sould I stop the order and get 135-3701 ?
brian41 is offline
Ken N
8
09-24-2008 02:35 PM
HARDCORE A/O
2
07-11-2005 05:26 PM
speedball
5
05-28-2004 12:28 AM
convincor
6
05-27-2003 02:45 AM
DanB
5
12-15-2002 05:44 AM
