oil capacity >
oil capacity
oil capacity
Old 11-13-2006 | 01:26 PM
Default oil capacity
Could someone please give me the oil capacity of a 2000 502 mag MPI and different filter numbers. Thanks in advance!!
kemiller is offline
Old 11-13-2006 | 06:44 PM
Default Re: oil capacity
Capacity is 8 quarts with filter. The most I've ever put in is about 7 quarts. You just can't get all the old oil out.
Check this thread for filter numbers.
http://www.offshoreonly.com/forums/s...filter+numbers
Griff is offline
Old 11-13-2006 | 06:58 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Correct, you cannot get all of the old oil out via sucking it out the dipstick.
You can drain all of the oil by installing a drain tube on the bottom of the pan. Mercury makes a kit for this.
Sydwayz is offline
Old 11-13-2006 | 07:36 PM
Indy's Avatar
Member #154
Good luck in a twin installation Next boat is staggered. I couldn't even get to the inboard drain plugs on my 502 during winterization. Had to go with the 10 gallon antifreeze method
Indy is online now
Old 11-13-2006 | 08:23 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
It can be done. You just need to find a "short person" who teaches Yoga.
Sydwayz is offline
Old 11-14-2006 | 09:07 AM
It already had a hose installed that is ziptied up by drive oil resevoir I just ran it out through the plug hole in the back and drained it into a pan. I couldn't imagine having another engine stuffed in there there's no room now!!
kemiller is offline
WHOSNEXT
2
06-21-2005 05:08 PM
firecatgreen
2
05-29-2005 08:27 PM
cig1988
3
07-06-2003 05:43 AM
Rambunctious
3
04-16-2002 01:07 PM
