1" Bravo Drive Spacer Studs >
Old 11-14-2006 | 04:28 PM
Thunderstruck's Avatar
Default 1" Bravo Drive Spacer Studs
I need 4 studs to put my spacers on but will consider a kit for the right $. Or, anyone know where to get individual studs?
Thanks in advance,
Tom Gurley
Thunderstruck is offline
Old 11-14-2006 | 04:51 PM
Default Re: 1" Bravo Drive Spacer Studs
I would try calling Imco.
Griff is offline
Old 11-14-2006 | 05:09 PM
The kit I put on from Teague came with the studs and also the coupler for the shaft. Where did you get the kit? It also came with the o-rings.
raytart is offline
Old 11-14-2006 | 05:50 PM
bought two 1" spacers from an OSO dirtbag who said they were complete. they were missing two studs, the orings and the rear bolt on each spacer. due to other difficulties with my rig, i didn't look at what he sent for months i cant even remember who it was. at least he sent the couplers which are $180 ea. caveat emptor
however i called Imco Nevada, per Griff, and Ron is sending the individual studs and bolts. Ordered the orings from Doller marine. Imco was cool to send individual studs. Livorsi wanted $100 for the stud kit and $50 for the washer kit, no individual parts available from Livorsi. I got 4 studs and two bolts for $7.50 each with $2.50 each or so for the orings minus shipping.
Thank you IMCO
Old 11-14-2006 | 05:52 PM
raytart, what application are you running? did your spacers work??
Old 11-18-2006 | 09:07 AM
28 Nordic Heat with Merc 525efi its/xr
Check out the Nordic Forum there is a Section of this topic
I believe it was call Drive spacer results or something like that. You could also see other posts by raytart and scroll down till you come across it. Good Luck with you results.
It worked well for mid-range cruising speeds. Not much up top. Check the thread.
Ray
(sorry for not responding sooner)
raytart is offline
Old 11-20-2006 | 09:51 AM
Raytart, looked up the thread. Thanks for the input. Got my spacers installed and looking to test maybe Friday. Need a south wind on the gulf to push some water up into the estuary so I won't scrub the bottom. I'll post results.
Tom
Old 11-21-2006 | 08:13 PM
Good luck. Hope it works out for you.
raytart is offline
Wahoo ATV
OPA/The Jersey Boyz
0
05-27-2008 08:32 AM
TEAMBAJA
05-04-2003 10:28 PM
