Breaking Roller Rockers?????? >
Old 11-16-2006 | 08:45 PM
Donzi502's Avatar
Default Breaking Roller Rockers??????
Guys we are breaking roller rockers on the race boat, 510 BBC with Mega Blower, about 950 HP. Dont run more than 6000 rpm and have just split another set of rockers. What type should i use. Thanks. Jas
Donzi502 is offline
Old 11-16-2006 | 09:23 PM
GNJ's Avatar
GNJ
Default Re: Breaking Roller Rockers??????
I assume you are using aluminum rollers? If so, you might switch to stainless steel rollers. A lot stronger. Comp cams and Crower make a set. Comp part number is 1120-16 for a set of 16.
GNJ is offline
Old 11-16-2006 | 09:32 PM
mcollinstn's Avatar
billet aluminum rockers ought not break. you sure they aren't bending and then losing the tip roller? Show us a pic.
mcollinstn is offline
Old 11-16-2006 | 11:57 PM
articfriends's Avatar
I don't know what brand your running but IF you buy comp magnum steel rockers to replace them THROW the nuts that come with them away,they caused me MUCH agravation. I'm running around 190 seat and 460 at peak open and turn up to 6000 rpm's on my motor,no rockers have broke yet,I also used the arp pro studs. I'm converting to T&D shaft style this winter to eliminate any potential problems,Smitty
articfriends is offline
Old 11-17-2006 | 02:41 AM
Donzi502's Avatar
They are stainless. Look like comp cams but i think are not. Have about 200 on the seat and run 6400 rpm. This is the second set. Split where the pushrod sits in the cup. Drove the pushrod right through the the rocker and smacked the stud gidle. Have top arp studs. This is odd. I never broke a rocker in years. No heat marks or blueing. Maybe we need Jesel shaft mounts. Or maybe aluminum will be more forgiving. Cost us two races now!!!
Donzi502 is offline
Old 11-17-2006 | 03:07 AM
Big Block Billy's Avatar
Thumbs up Re: Breaking Roller Rockers??????
Run the Crower arms.... Much less weight at the valve stem especially after doing the math was everything else totally on point ? We are constantly being humbled with all of this stuff. When we think we know it all, that"s when something unforseen comes up and bites us in the @ss,,.BBB
Big Block Billy is offline
Old 11-17-2006 | 06:39 AM
SB
Valve floating issue ? Are we running the correct springs and are they installed correctly ? Geometry correct ? Rockers touching retainers ?
Are these HR or Solid Roller ?
Should you be running a shaft rocker for your application ?
SB is offline
Old 11-17-2006 | 08:52 AM
KAAMA's Avatar
I have always been told that the weakest link in a Big Block Chevy is the valve train. They cost more, but the shaft mount style rockers are much more reliable/stable vs the very old stud mount design.
KAAMA is offline
Old 11-17-2006 | 07:31 PM
Elite Marine's Avatar
The geometry of the valve train in a big block is ridiculous!!
Push rods go every way except straight up and down. If you are running 6000+ RPM you really should invest in shaft rockers.
I'm with Smitty and installing T&D shaft with the priority oiling system on my new engine. It's the only way to eliminate potential issues.
Good Luck!!
Elite Marine is offline
Old 11-17-2006 | 07:42 PM
nocigarette's Avatar
not that i havent blown up a lot of sheet but shaft mount rockers jesel all the way it is the only thing in my motor that has not pucked up yet
nocigarette is offline
