HP 500's-Most hours?
Old 11-18-2006 | 08:23 PM
Default HP 500's-Most hours?
Who has the most hours on HP 500 EFI's? Im @ 430 and they run great, but I hearing refresh soon. Wondering who has run them up and who has refreshed-chose to or had to?
Thanks in advance.
PS- If refreshing, Im thinking of whipples and drive beef up- might as well get some more power while they're out-any feedback on that setup would be cool.
motobri is offline
Old 11-18-2006 | 09:11 PM
TeamSaris's Avatar
Driver-441
Racer
Default Re: HP 500's-Most hours?
The Whipple is the best blower out there and you will be very pleased!!
TeamSaris is offline
Old 11-19-2006 | 07:06 AM
Airpacker's Avatar
my 500efi is out for rebuild ( bore/stroke) after 447 hrs by choice. I figure at least 1/2 of those hours are at 5000 rpm or better. Solid piece of performance engineering. Now, if only drives would last that way
Airpacker is offline
Old 11-19-2006 | 09:19 AM
BAJA WILL's Avatar
Registered User
I am around 450 hours changed my valve springs around 350, Did a leak down and mech said the pressure was still like new, in great shape. SO I am going to keep her stock and keep going.
WILL
BAJA WILL is offline
Old 11-19-2006 | 10:53 AM
UNSANE's Avatar
Originally Posted by BURGER&FRIES
Are they fresh water cooled like the 525's??
No, I don't think so. I'm told that the only difference between the 500's and the 525's are the aluminum heads built for Merc by Edelbrock and the closed loop cooling.
UNSANE is offline
Old 11-19-2006 | 11:16 AM
THEJOKER's Avatar
500 efi is the "Official Engine" of ORL. Affordable , dependable and there are many out there. If you guy's know where some are for sale let me know! Thanks.
www.offshoreracingleague.com
THEJOKER is offline
Old 11-20-2006 | 11:28 PM
Smile Re: HP 500's-Most hours?
WILL
Just springs and no valve job? I was told Valve job needed motors pulled and might as well rebuild?
I think I'll run leak down first and then see if I can milk em for another 400
Anyone else got high hours w/ no work done?
motobri is offline
Old 11-20-2006 | 11:30 PM
Not closed cooled and yes have been salty 1/2 dozen times-
motobri is offline
Old 11-20-2006 | 11:32 PM
75% of my hours have been under 4500 rpm, do you mind sharing the total cost for your rebuild, roughly?
Lucky for me drives have been solid for XZ's. One minor repair.
motobri is offline
Old 11-20-2006 | 11:37 PM
berns29scarab's Avatar
Thanks in advance.
what make and model boat are they in ? weight ?
berns29scarab is offline
