engine builder says gear drine >
Old 11-19-2006 | 07:05 AM
nocigarette's Avatar
Default engine builder says gear drine
should i be putting a milodon gear drive in my gen 6 572, that is what the engine builder is telling me he wants the timing to be precise.............or is he looking in the wrong direction
nocigarette is offline
Old 11-19-2006 | 09:22 AM
Panther's Avatar
Frank's Marine Service
Default Re: engine builder says gear drine
I hear the harmonics on a gear drive aren't too good....
If you want something good, get a Jesel belt drive.
Panther is offline
Old 11-19-2006 | 10:58 AM
Crazyhorse's Avatar
Tell your engine builder "Jessel belt drive" if he wants precision.
If you want to stay with a chain you will want the Cloyes Tru-roller. Go to the website and check them out. Great product, great warranty
Crazyhorse is offline
Old 11-19-2006 | 01:07 PM
Elite Marine's Avatar
Belt drive is the best.
Elite Marine is offline
Old 11-19-2006 | 05:27 PM
GPM
What is the lifespan of that belt, what do the valves and pistons look like when it breaks ?
GPM is offline
Old 11-19-2006 | 07:05 PM
nosig,
Personally, I have used a few gear drives at customers request, several Jesel belt drives on drag race engines, and a LOT of good old reliable Cloyes True Roller chain sets. I have never had any of them fail. I cannot speak to the "harmonic" issues with gear drives either.
That being said ... you have to be able to trust your engine builder. If he is going to stand behind his product, you really need to do what he wants to do. If he prefers gear drives, and has had good success with them, then let him do his part of the job the way he wants to do it. If you cannot trust his decisions, you probably should be using another builder, or doing it your self. I know this sounds harsh, but it is a fact of life.
Just my opinion,
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
BillK is offline
Old 11-19-2006 | 07:19 PM
Well put Bill!
Old 11-19-2006 | 07:39 PM
Reed Jensen's Avatar
The problem with gear drives is they impart an opposing load on the cam and crank... Simple terms.... the crank and cam are pushed away from each other... A chain pulls the two together. The oil port on the camshaft is on the "bottom" where the load is for a chain. I've only heard anecdotal theories about "harmonics" being transmitted through the gears. I think Jesel belt drives are cool... They allow you to change timing without having to remove the damper and cover, but I wouldn't run one other than on a dyno for a short time to determine what cam timing works best for your application. Those belts are tiny compared to gilmer cogged drive belts on overhead cam engines. Even those belts have a short life and they're opening tiny valves by comparison. Go with a good roller chain. Early ford engines had gears... but only two... and one of them had a damper built into the gear to take out the harshness. The engines were designed to have the camshaft turn in the opposite direction of the crank and the gear faces were helical cut for less shock and noise.
Reed Jensen is offline
Old 11-20-2006 | 07:23 AM
Thanks guys, i trust the guy but i also like to due my own research.........The harmonic theroy i have heard before and undue stress on camshaft............I guess i will due what he says, he wont let me buy anything but the milidon gear drive and it is more exspensive than any chain and a little less than the jesel...............BACK UP AND PUNT I GUESS............
Old 11-20-2006 | 08:18 AM
Panther's Avatar
Not good when it breaks, I'll tell ya that first hand... My "old" builder insisted on putting in a certain manufacturers timing set and of course it didn't last. Half my valves were bent and the motor had to be completely rebuilt..
Panther is offline
