alarm codes for 525 merc ? >
Old 11-21-2006 | 07:06 PM
Default alarm codes for 525 merc ?
does anyone have the link for the alarm codes for the 525efi motor .. the alarm beeps 5 times and the motor wont go over 3000rpms.. i was told that it is the gear shifter not fully ingauged i just wanted to double check
thank you
mike
mikebrls is offline
Old 11-21-2006 | 08:04 PM
Ted G's Avatar
Default Re: alarm codes for 525 merc ?
You need to read the code it is in one of the power reduction modes. If you suspect a neutral switch, disconnect it and see what happens. If the switch is bad or misadjusted it will spin right up with the switch disconnected. I have seen these go out of adjustment and cause it to go into power reduction.
www.cbpba.com
Ted G is offline
Old 11-21-2006 | 08:54 PM
I scanned this out of my manual for my 2005 Merc 525. Hope it helps. There are a few problems listed that give 5 beeps - but none of the ones shown activate the Guardian System.
Good luck
Attached Thumbnails alarm codes for 525 merc ?-scan-page-33.jpg   alarm codes for 525 merc ?-scan-page-34.jpg
raytart is offline
Old 11-21-2006 | 08:58 PM
Thank's A Lot
mikebrls is offline
Old 12-18-2006 | 07:47 PM
What was the outcome?
raytart is offline
Noise Pollution
6
03-26-2008 08:30 AM
Magic34
10-24-2007 05:05 PM
ecstatic
3
09-25-2007 04:03 PM
dfealy
11
09-21-2007 04:07 AM
tmthunder
4
09-12-2004 08:33 PM
