383 build started
Old 11-21-2006 | 08:35 PM
Default 383 build started
This should get interesting. Tore down the MX 6.2 today, pretty high quality stuff Mercruiser put in. I and the guys at CHS racing were impressed. Looking for 450 ish at the crank, shouldn't be a problem. I know a few here have done the build up already, any suggestions????
unbroken is offline
Old 11-21-2006 | 08:50 PM
BOOSTEDSCARAB's Avatar
Default Re: 383 build started
Merc use's good stuff. I have built 2 sets of 383's putting out no less then 485 hp,...on pump gas. Use the best heads u can afford...be sure and have good comunication when buying and or having work done. In other words tell them you RPM range, and thats its for a boat obviously.
The only other motor I would build other then a 383 would be a LS2 punched to a 402. Sweet
Have fun with the build
BOOSTEDSCARAB is offline
Old 11-22-2006 | 06:32 AM
offshoredrillin's Avatar
my cousin just took my old 383 with edelbrock heads, 510 hp and in a 69 camaro with street tires ran a 12.56 at MIR raceway... they are great motors, torque pigs
offshoredrillin is offline
Old 11-26-2006 | 06:55 PM
I just had a large infusion into my bank account, so its going to be done the right way. I am thinking aluminum heads, Darts. SO the 383 makes pretty good torque????
unbroken is offline
Old 11-26-2006 | 08:35 PM
heck yea boy...check with JC performance on here. you wont be disappointed with a 383, if done right torque can be over 525 easily.
Old 11-27-2006 | 10:20 PM
I did a pair a few years ago in a 27 Hallett.
Dynoed at 447/477
EMCO exaust
AFR 190 heads (Highly reccomend!!)
Edlebock RPM (1" spacer)
Comp Hyd roller
750 Holley
10.6-1 CR
91/92 oct a must w/32 total timing and no more!!
used KB Hyperutectic pistons
and Chinese cast cranks, motors are still running strong.
This realy turned out to be a great little package and relativly cheap. If your mostly lake running and have rev limmiters they will live a long time.
KL
CAFormula1 is offline
magstang1
19
09-04-2008 04:37 PM
thedonz
8
09-05-2006 10:24 PM
estonian
35
10-27-2005 11:22 PM
Superboat
06-06-2003 12:10 AM
