Will a pair of HP500 GIL Manifolds fit a Merc. 454?
Subscribe
11-22-2006 | 09:02 AM
Anyone?
Reply 0
11-22-2006 | 09:07 AM
Re: Will a pair of HP500 GIL Manifolds fit a Merc. 454?
Yes
Reply 0
11-22-2006 | 09:46 AM
yes and you may need to find a way to mount the shifter mechnism and oil filter if it mounts on your original riser bolts.
I believe imco may have some brackets but you may have to check bolt location.
Reply 0
11-22-2006 | 12:42 PM
Yup, should bolt right up.
Reply 0
11-22-2006 | 12:58 PM
When I installed my Gils I moved the oil filter to the transom on a bracket I fabbed, very easy to change the filter with -0- mess with a plastic jug bottom held under it. The shift bracket had to br moved outboard on the riser, I did not have enough clearance for the carb plumbing.
Reply 0
11-23-2006 | 05:28 AM
The manifolds will bolt right up without a problem. We have adapter brackets available if you need them.
http://www.hardin-marine.com/product...ccessories.htm
Reply 0
11-23-2006 | 04:31 PM
I've got an original set of brackets (2) for twin engine set-up. $50 shipped in the USA. Pm me if interested!
Dave
Reply 0
