Edelbrock Aluminum Heads
Old 11-22-2006 | 02:45 PM
gripit's Avatar
Default Edelbrock Aluminum Heads
I'm thinking about getting a set of oval's for marine that come anodized. It seem like a great deal 2 aluminum heads for 1300.00 and some inconel valves. I think the real value is that they come anodized. Who likes these heads and who dis-likes these heads? Thanks
http://www.edelbrock.com/automotive_...t_bb_rpm.shtml
MARINE-DUTY PERFORMER RPM 454-O AND 454-R
Heavy-duty, 1.89" Inconel exhaust valves provide added durability for marine applications
Hard anodized to protect the aluminum in the harsh marine environment
Sold with valves only to allow for valve spring choices
Match with an Edelbrock Performer RPM manifold, Performer Series 750 cfm marine carb and Performer RPM cam for proven performance
Smaller-than-stock 11/32" valve stems promote excellent flow and lighter valve weight
PERFORMER RPM 454-O MARINE OVAL PORT
Chamber Size Intake Port Size Valve Sizes (in/ex) Bare (single) Complete (single)
110cc 290cc 2.25"/1.89" N/A #61459*
gripit is offline
Old 11-22-2006 | 05:41 PM
Smitty's Avatar
Default Re: Edelbrock Aluminum Heads
I run the rectangular ports on my rig. Supercharged application. Out of the box they didn't flow very well at all. Spent some cash to have the exhaust side opened up as well as bowl ported. Now they flow REALLY well. Hope this helps somewhat.
Smitty is offline
Old 11-23-2006 | 09:47 AM
I had the oval port heads on a 454 years ago and they worked great. Good all around performance from idle to top end. We targeted and got max HP at around 5400 rpm. Dyno HP was in the 460-470 HP range. I don't remember the torque number. Tyler Crockett specified the cam and carburetor and built the engine. He also worked the heads a bit and installed larger valves. Last I heard the engine was still running strong, eight years later.
Escape Velocity is offline
Old 11-23-2006 | 10:20 AM
JIMKID Motorsports's Avatar
I Put A Set Of Performers On A396 Street Car Motor Right Out Of The Box 20 Miles Later Hung A Valve In The Guide Hit The Piston Not Pretty Guides Were To Tight From The Factory You Get What You Pay For Have A Good Head Shop Check Them Out Before Useing Them
JIMKID Motorsports is offline
Old 11-23-2006 | 11:34 AM
KAAMA's Avatar
Someone here on OSO from the Detroit area bought 2-sets of the Edlebrock aluminum heads and had JimV flow test the heads as they came from the factory out of the box---they don't flow too well. JimV did a partial port job for the guy and got them to flow much better.
KAAMA is offline
Old 11-24-2006 | 12:30 PM
Smitty's Avatar
Kaama-
I am the guy that worked with Jim V. and those heads. See post above. I am from Chicago area.
Smitty
Smitty is offline
Old 11-24-2006 | 08:48 PM
gripit's Avatar
An engine builder told me he uses the Edelbrock rectangular port intake manifold with the Edelbrock oval port heads to create a tunnel ram effect. Does anybody do this?
gripit is offline
Old 11-24-2006 | 09:01 PM
10x's Avatar
10x
10x
Unless you got the applications reversed, stay clear from that engine builder.
Fountain powerboats rule "The Preacher"
Chicago Powerboat Club Director
[email protected]
www.chicagopowerboat.com
10x is offline
Old 11-24-2006 | 09:05 PM
BTW there was just something in this months PowerBoat Mag about a buildup using some of those heads with a bunch of part numbers listed.
Back4More is offline
Old 11-24-2006 | 09:22 PM
topfuel's Avatar
I agree with 10x. I have used oval port intake manifolds with rectangular port heads in certain applications. It really increases throttle response and intake velocity.
topfuel is offline
