C4500
Old 11-27-2006 | 05:54 PM
TeamSaris's Avatar
Driver-441
Racer
Default C4500
We are looking into getting a new "race truck" to pull the race boat. Does the 4500 pull any better than the 3500?
We have had 4500s in the past but never a 3500.
Thanks,Johnny
TeamSaris is offline
Old 11-27-2006 | 06:01 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Default Re: C4500
Had a conversation with a professional CDL driver who has pulled the same loads with the GM C-4500 and the Ford F-650.
Straight from experience, he stated the F-650 is twice the truck of the GM.
Sydwayz is offline
Old 11-27-2006 | 06:05 PM
TeamSaris's Avatar
Driver-441
Racer
Default Re: C4500
The owner/driver of the raceboat owns a GMC/Subaru dealership. So that counts out ford.
Old 11-27-2006 | 06:26 PM
Default Re: C4500
how can you compare a f650 to a c4500 ? The c4500 is the same gvw as a 450 superduty. I just changed from a f450 to c4500.I had very good luck with f450's but didn't want to chance ford new diesil. Ihave to tell the c4500 puts the f450 to shame. it pulls my 92 top gun or my 40' motorcycle trailer with ease, so far no regrets to swapping to chevy...
38tg is offline
Old 11-27-2006 | 07:19 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Default Re: C4500
Its not me that compares them; I know the difference. BUT, many think that since the C4500 and the F-650 trucks are the first jumps for both manufacturers to "larger" trucks, that they are of the same caliber.
I should have qualified my response better.
Sydwayz is offline
Old 11-27-2006 | 07:21 PM
BUIZILLA's Avatar
instigator
Default Re: C4500
Originally Posted by Catmando
The F650 uses the Cat C7 which can be pumped up from 300hp to 425hp.
I would be VERY interested in this info..
JH
BUIZILLA is offline
Old 11-27-2006 | 07:25 PM
Registered User
Default Re: C4500
Cat power upgrades are unbelievably expensive. At a minimum, the lower-end bumps (like from 200 to 250) require turbos and injectors along with a reflash. The bigger one's require pistons, dampers, fans, radiators and intercoolers and I think the biggest require cranks. Then you have gearing changes to address. Basically, if you are looking at a truck and think you need more HP, call Cat first.
Chris Sunkin is offline
Old 11-28-2006 | 11:21 AM
Default Re: C4500
The new style 4500 is completely different truck than a 3500 which is based off the light duty pick ups. The 4500 is a medium duty and 16,000+ lb loads are where they shine. The Duramax has a lot of torque which is what counts. The F650 as stated compares with the C6500, different animal.
The 4500 is very nice for a Medium duty truck, and comfortable.
Wannabe
wannabe is offline
Old 11-28-2006 | 12:44 PM
tblrklakemo's Avatar
SeaRay Sundancer
Default Re: C4500
http://www.f650pickups.com/page0009.html
this truck with cat power....yes please.
Honestly, I wouldnt have any prob pulling with either medium duty truck. However I might be a bit bummed if the guy in his 2500HD has the same duramax as my 4500.
tblrklakemo is offline
Old 11-28-2006 | 12:47 PM
Registered User
Default Re: C4500
One downside of the Cat is they're loud- much louder than an Int'l or MBZ. Upside is they have thousands of 24-hour service shops across the country.
