Aircraft wiring on a 500 EFI? >
Old 11-29-2006 | 03:23 PM
Default Aircraft wiring on a 500 EFI?
I am assuming that the motor is sealed and to sanctioning bodies spec.....it is on the water pump , intakes bolts , fly wheel and has a serial # on all the tags.....WHat gives.
Bryan
Bryan Rose is offline
Old 11-29-2006 | 09:22 PM
Default Re: Aircraft wiring on a 500 EFI?
Nobdy knows..........................................
Old 11-29-2006 | 10:25 PM
Exactly what are you asking????????????
Griff is offline
Old 11-30-2006 | 12:28 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
Bryan, I too am not sure what your question is??? Feel free to call me tomorrow ( I will be in the shop all day)... I can try to get you an answer to your question.. It probably just has to be rephrased.. Jamie / Lakeside 570-639-2628
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 11-30-2006 | 12:33 AM
racesdad's Avatar
intakes, oil pan, harmonic balancerand water pump
racesdad is offline
Old 11-30-2006 | 02:00 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
They seal them with little marks of paint on all of the bolts. They do not use "safety wire" as we used to call it in motorcycle and PWC racing.
Sydwayz is offline
Old 11-30-2006 | 07:21 AM
I will get some pictures of the safety wiring and post them aall water pump bolts ( hex HEad cap ) intake and harmonic balancer bolts are safety wired and all have matching serial #'s on them.
Bryan
Old 12-07-2006 | 07:41 PM
As an Aircraft mechanic, why would you safty wire the harmonic balancer bolts. it would throw the balancing off i would think.
jonwrob is offline
Old 12-08-2006 | 09:07 PM
My 500EFI has the wire being discussed on at least one intake bolt, haven't seen any elsewhere on the motor. Mine is a 2001 year model, and I believe the wire is a tamper seal, desiginating the motor was assembled by Mercury Racing.
Larry
62 Bel-Air 409
260 Eagle XP HP500EFI
2002 Corvette M6 Coupe
Bubbletop409 is offline
Old 12-08-2006 | 09:09 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Why on the WP? ..........Timing cover.?
US1 Fountain is offline
