Air conditioning duct material >
Old 12-01-2006 | 05:49 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Default Air conditioning duct material
What determines whether insulated or non insulated ducting gets used for A/C?
US1 Fountain is offline
Old 12-01-2006 | 06:01 PM
ericaull's Avatar
Default Re: Air conditioning duct material
COST
ericaull is offline
Old 12-01-2006 | 06:05 PM
I am thinking cost. I believe it is so the cool air stays cool till it reaches its exit point. Why let cool air escape or warm air enter the ducting?,especially in hiden voids or compartments.
johnny b good is offline
Old 12-01-2006 | 06:11 PM
Ginger or Mary Ann?
Not worried whether I spend $11 or $17 for duct for a 25' peice. The insulated I think has no draw back, other than running it because of the larger size, which I am trying to work around. The A/C unit and 1/2 of the duct will be in the cabin, but do to the unit placement, I have to run the supply duct through the cabin wall and into a void between that wall and the cockpit liner, which is open to the side storage compartments and the bilge in the back of the side compartments. So not quite the same as running duct work thru the engine compartment directly.
Old 12-01-2006 | 06:13 PM
Ginger or Mary Ann?
Damn I type slow.
Old 12-01-2006 | 08:30 PM
t500hps's Avatar
21 and 42 footers
I ran duct through a forward cabin bulk head and only cut it big enough for the 4 inch material to pass through. I ran the insulation around both pieces on either side and everywhere else it was convienent to use.....the last 1-1.5 feet weren't insulated either due to space constraints.
t500hps is offline
Old 12-02-2006 | 08:18 AM
US1, Insulated duct should always !!!!!!!! be run in non -conditioned areas. If not you have the potential to form condensate on the outside of the duct because of the temperature difference.
Dave
David Stotz is offline
Old 12-02-2006 | 09:07 AM
Dave
Bingo........!!!
pullmytrigger is offline
Old 12-02-2006 | 12:21 PM
PMT, Are you in the business ?
Old 12-02-2006 | 07:15 PM
Yessir...
