Does anybody use rear plate style motor mounts? >
Old 12-04-2006 | 10:39 AM
phughes69's Avatar
Default Does anybody use rear plate style motor mounts?
I already have the Gil Offshore front motor mount and wanted to know if anyone used the mid plate mount too?
phughes69 is offline
Old 12-04-2006 | 10:51 AM
Default Re: Does anybody use rear plate style motor mounts?
They're primarily used in staggered setups.
My staggerd Scrab used the back plates on both motors though. If you want to use them, you'll need to have the bell housing machined to take in accout the thickness of the plate between the block and bell housing.
Gary
rdoactive is offline
Old 12-04-2006 | 11:03 AM
phughes69's Avatar
Would they be worthwhile in a side by side set up?
Old 12-04-2006 | 01:22 PM
I dont think I've ever seen a failure of TRS or SSM tranny tailstock mounts. So it may be a bit of overkill for a plug in setup.
Old 12-04-2006 | 01:31 PM
10x's Avatar
10x
10x
I've got them in my side by side setup.
Attached Thumbnails Does anybody use rear plate style motor mounts?-image00039.jpg   Does anybody use rear plate style motor mounts?-image00040.jpg   Does anybody use rear plate style motor mounts?-image00041.jpg
Fountain powerboats rule "The Preacher"
Chicago Powerboat Club Director
[email protected]
www.chicagopowerboat.com
10x is offline
Old 12-05-2006 | 08:11 AM
phughes69's Avatar
Would there be any benefit to a TRS plug in style setup?
Old 12-05-2006 | 11:01 AM
Reed Jensen's Avatar
I had them in my boat too... along with the SSM rear mount.
Reed Jensen is offline
Old 12-05-2006 | 12:15 PM
Here is mine on a plug-in side by side set up.
Jim
Attached Thumbnails Does anybody use rear plate style motor mounts?-screenhunter26_resize.bmp
Lunatic Fringe is offline
Old 12-05-2006 | 01:03 PM
phughes69's Avatar
Reed, what does the SSM rear mount look like?
Nordicflame
Wanted
9
11-13-2008 12:59 AM
kvogt
Wanted
0
06-03-2008 11:01 AM
resurrected
9
03-25-2005 01:19 AM
ASD-6
12-03-2002 07:21 PM
