Anyone change the front hubs on a superduty? >
Old 12-04-2006 | 12:38 PM
BajaRunner's Avatar
Default Anyone change the front hubs on a superduty?
I am changing mine to the warn manual locking hubs. anyone ever do this? looks easy, just dont want to phuck it up.
BajaRunner is offline
Old 12-04-2006 | 03:52 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Default Re: Anyone change the front hubs on a superduty?
Haven't change mine over, but I did have to tear the front hubs and axle apart to replace the inner oil seals. '03, Nothing to it.
US1 Fountain is offline
Old 12-04-2006 | 04:22 PM
For complete info go to http://www.thedieselstop.com/
Finman
FINMAN is offline
Old 12-04-2006 | 04:57 PM
Registered User
Do the wheel bearings and lower ball joints while you're in there. Neither will last 100K.
Chris Sunkin is offline
Old 12-04-2006 | 07:05 PM
mopower's Avatar
Toxic FORMULA
Changed mine to Warn last spring. Took all of 15 minutes...total.
mopower is offline
Old 12-04-2006 | 10:22 PM
Smitty's Avatar
Pop the snap ring off and pull the hub assembly out, pop the new one in and away you go !!
Smitty is offline
Old 12-05-2006 | 03:11 PM
mopower's Avatar
Toxic FORMULA
Exactly
mopower is offline
Old 12-07-2006 | 06:48 AM
MattBMiller's Avatar
The stock hubs may be stuck in there. Use a 2x4 or a rubber mallet bo break them loose. I like the MileMarker stainless hubs for a bit more money thatn the Warns. I've used them on my last few trucks.
Matt
MattBMiller is offline
Old 12-09-2006 | 03:10 PM
Real easy to do like someone else said 15 minutes max
Shane B is offline
Old 12-14-2006 | 07:42 AM
BajaRunner's Avatar
one was super easy, one (the bad one) was stuck. still didnt take long. thanks for the tips!
CigDaze
Baja
4
08-19-2004 08:10 PM
Cattitude
14
03-17-2004 04:46 PM
buck183
08-08-2003 07:59 AM
Waterfoul
05-06-2003 09:09 PM
ck54
07-13-2002 06:52 AM
