stern lift >
stern lift
stern lift
Old 12-09-2006 | 02:35 PM
mtm's Avatar
mtm
Default stern lift
what are my options for stern lift props
last year I was running bravo 4 blades 32 1.51 6000rpm 101mph and there was still more left.
I swapped prop rotation from out to in and I liked the stern lift . that's how the boat ran when I got the boat with 27 hydros q4s I also tried 32 maxims turning out and the same bow lift
Thanks Mike
mtm is offline
Old 12-09-2006 | 02:45 PM
Default Re: stern lift
Sounds like you should test a set of hydro P5's. Its a 5 blade version of the Q4's and will give more stern lift than the Maximus props.
Griff is offline
Old 12-09-2006 | 02:57 PM
Also, send a PM to Gordo. He had set of 32 P5's that he was looking to sell or trade. It was a while ago, so I don't know if he still has them.
Griff is offline
Old 12-11-2006 | 08:27 AM
throttleup's Avatar
Here are your options:
Hydromotives
Herings
Throttle Up CNC props
These are the only companies making stern lifting Bravo Style drive props. If you are interested in the CNC props feel free to call me and we can discuss your goals!
Julie
throttleup is offline
Old 12-11-2006 | 12:07 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: stern lift
Stern lift is created by blade area and geometry. This means most any propeller can be modified to otain more stern lift than they currently have.
We can change Mercury B1 and Maximus's to add more stern lift. There are however, certain propellers that can have more stern lift or, lack of bow lift, than others. Those are propelles with low rake angles, large diameters and cleaver type trailing edges such as the Hydromotive Q4 or P5.
[email protected]
bbladesprops is offline
Old 12-11-2006 | 10:33 PM
mtm's Avatar
mtm
Thanks all
mtm is offline
Old Navy
Prop Talk
22
08-05-2008 04:24 PM
PARADOX
04-28-2008 11:30 AM
Back4More
Prop Talk
1
06-28-2006 12:03 PM
ROTAX454
Prop Talk
6
09-21-2005 10:34 PM
Kokopelli
Warlock
8
04-02-2002 09:10 PM
