7.4 to 525sc swap exhaust problem >
Old 12-14-2006 | 12:36 AM
Default 7.4 to 525sc swap exhaust problem
I swaped a 7.4 mercruiser to a 525sc in a 1997 Mariah 25'. all is going well but I have a problem with the exhaust. The Gil manifolds or risers do not line up with my existing exhaust.( I sold the old lady on the sc motor but she's not willing to lose the silent choise) What i am wondering is : Is there a riser that will work with my Gil manifolds and has the same (or close to same) exit position as a stock mercruiser 7.4. this seems like the easy fix. but i am open to sugestions. THANKS
bigbsbigblocks is offline
Old 12-14-2006 | 12:41 AM
MM1
Default Re: 7.4 to 525sc swap exhaust problem
Yes, contact cpperformance.com and you can order the correct risers
MM1 is offline
Old 12-14-2006 | 12:54 AM
I would like to find a used part or another option first ,before I go that route. but your right CPP is a great source. thanks
Old 12-14-2006 | 06:48 AM
Payton's Avatar
Charter Member #927
Getout your chop saw and wekder. Actually I shortend some used, Gil/trs risers. I made 2, 45* cuts then twisted the pipes untill I lined up with the Bravo tips. I made a magic Marker line on the pipes, brought them to a friend to TIG weld. I heated the inner pipe,at my first cut, and drove a wedge into it to expand the inner pipe out to the outer, leaving enough gap to equal the holes that Gill had to let the water enter the exhaust stream.They worked great.
Payton is offline
Old 12-14-2006 | 06:53 AM
nice job !
open87 is offline
Old 12-14-2006 | 07:27 AM
Superboat Guy's Avatar
You can all make aluminum wedges and short riser blocks to make adjustments. I made a pair of wedges for my boat, about 1 1/2" on the big end sloping down to about 3/8" on the short. Worked very well, they run a bit warm but not to bad.
Superboat Guy is offline
Old 12-14-2006 | 08:35 AM
Gil sells wedges for up/down adjustment. They go between the manifold and S/S riser. They were kind of pricey so I had a machine shop make a set of 4 for about $50.
rdoactive is offline
JasonSmith
Baja
4
11-25-2005 01:32 PM
dykstra
21
08-08-2005 05:39 PM
JJONES
0
07-08-2005 08:00 PM
Formula Outlaw
10-30-2004 07:47 AM
Formula Outlaw
08-12-2004 08:59 PM
