Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Pulling my hair out......pros please! >
Old 12-16-2006 | 04:51 PM
24degrees's Avatar
Default Pulling my hair out......pros please!
I'm painting a car with Spies-Hecker single stage urethane. The paint turns out pretty good but we are trying to make it very nice.......so my painter friends tell me to D/A with 1500 wet then 3000 wet....then buff.
Well......I do the D/A to 3000.....the paint looks nice and smooth.....then I buff and all you can see is scratches.....they are circular so I'm assuming they are 1500.
We've even started with 2500 a couple days after paint and it looks like hell when we buff......big straight scratches.
The guy doing the body work is a pro with 15 years experience.....the Standox primer surfacer was blocked with 800 before paint......
I know it's hard to help but I need some suggestions....
Thanks,
Aaron
24degrees is offline
Old 12-17-2006 | 08:58 AM
later's Avatar
Default Re: Pulling my hair out......pros please!
sounds like you havent buffed the scratches out yet, keep buffing
later
later is offline
Old 12-17-2006 | 09:12 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
Did you use a compound? Also what polish & Compound if any are you using?? I have found that 3m & Presta's stuff works well. Also are you using foam or wool for the polishing (not compounding)..? Jamie / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 12-17-2006 | 10:25 AM
Cool Re: Pulling my hair out......pros please!
We painted my 30' Sutphen with Spies- Hecker, I used 3M Buffing & Polishing Compound. After your done buffing ,I used 3M Liquid Ebony. No swirl marks,Just Shine!
818181 is offline
Old 12-17-2006 | 12:17 PM
It sounds like you are using to agressive of a compound or pad.
3M perfect it compound with a foam pad wors well and follow with 3M Ultafina with the blue foam pad.
RBeyer is offline
Old 12-17-2006 | 01:17 PM
Thats what I was thinking he may be doing as well. Also possibly there was no compunding before polishing after the sanding was done, or maybe not enough?? Jamie /lakeside
Old 12-17-2006 | 03:47 PM
24degrees's Avatar
Thanks guys.....we're using foam pads and various 3M compounds but I can't remember what.
I'll check when I get to the shop tomorrow.
Old 12-18-2006 | 08:25 PM
24degrees's Avatar
Could the mixing ratio have an effect on how hard the paint is?
The data sheet says 3:1 of the hardner we have so that's what we did.
The paint can says 2:1 of some other hardner......?
Thanks again,
Aaron
Old 12-18-2006 | 09:14 PM
It can depending on what you ended up with However if it ended up too hard, you should stil be able to wet sand, compound & polish it out. Depending on how it was mixed it could have also cured to soft. If that was the case your sanding & polishing pads & finish would be gumming up.. Just a thought.. J
Old 12-18-2006 | 11:00 PM
Audiofn's Avatar
Charter Member #232
Make sure that you are using the correct pad with the correct pollish. I had my landloard barrow stuff from us and he came back all pissed that the stuff that he was doing was not as nice as what we did. He had reversed the pads and chemicals.....
Put your best foot forward!
Audiofn is offline
