29 fever props ? >
29 fever props ?
29 fever props ?
Old 12-17-2006 | 11:50 AM
Default 29 fever props ?
Just recently purchased a 1997 29 fountain with 454 mags in it and was wondering what props would work best on the boat for top speed ?
chkmt251 is offline
Old 12-17-2006 | 02:17 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Default Re: 29 fever props ?
Dit it come with the performence sheet from Fountain? If not, you can call the factory wiht your hull ID numbers and they will fax it too you. Has all the trim settings, rpm, speed, weight info from the test drive with the props.
US1 Fountain is offline
Old 12-17-2006 | 05:35 PM
Yes it did come with the spec sheet it has 14.5 by 26 4 blade Mach props on it but almost all the other fountains I have seen have hydros on them and was just wondering if they would be a better selection.
chkmt251 is offline
Old 12-18-2006 | 08:21 AM
throttleup's Avatar
Any semi-cleaver propeller typically produces great results.
I would typically recommend Hydromotive for stock props and Throttle Up for CNC Props.
Post your performance data and we can take a look.
Julie
throttleup is offline
Old 12-20-2006 | 12:47 PM
The spec sheet says 79 mph at 4950 rpm tabs at 3.0 and drives at 5.3 . 60 mph at 3650 rpm
chkmt251 is offline
Old 12-24-2006 | 08:53 PM
Rookie's Avatar
where are you located, i have some 24 HYDRO Quad IV's in 24" collecting dust. They seem to work good for fountains. I am in MI and if you are close I would let you give them a try. Just might have to wait a month or 3.
Rookie is offline
Old 12-26-2006 | 10:33 AM
throttleup's Avatar
chkmt251,
What is your gear ratio?
What props were run at the 4950 RPM at 79 MPH?
I want to look at the propellers efficiency before recommending a propeller to you.
Julie
Old 12-26-2006 | 02:42 PM
It has 1.5 bravos and the props used were the mach 4 blades 14.5 x 26
chkmt251 is offline
Old 12-26-2006 | 03:53 PM
I would have to say a 25 hydromotive or a 24 merc 4 blade is just what the docter will say for that application. Get rid of the Machs those are Junk! My preference would be a 25 Hydro maybe even a 26. But I think with 385hp and 1.5 bravos the 25 hydro or the merc 26 is the prop. Anyone else agree?
runafever is offline
Old 12-26-2006 | 05:28 PM
What speed difference do you think the hydros will make over the machs? Thanks to everyone for helping me out with this .I owned a 25 ft checkmate before so this fountain thing is all new to me.
chkmt251 is offline
