Removed Accessories and Mounts
I recently removed my engine mounts, hydraulic steering, pitot tubube hose , drive indicator cable and water dump from the transom of my boat.
I planned on drilling out the holes that went through the transom to get to wood and remove the 4200 sealant, cut dowels to length, coat them with resin and insert them in the holes. Once dry, I planned on using resin mixed with filler to patch the holes and then take the boat to a gel guy for finishing.
Is this the right/best way to do this work?
Seems right and easy.
Thank you,
Kirk
Thank you,
Kirk
Charter Member #139 /Moderator/Platinum Member
Kirk,
Thats they way I plugged holes in the Bullet and they held up very well
How is the project coming along?
Klaw
Klaw
Kept the Bullet and the condo and joined the cig 20 restoration club.
