'05 F350 Diesel Computer Reflash >
Old 12-18-2006 | 06:48 PM
racinfever's Avatar
Default '05 F350 Diesel Computer Reflash
I recently took my truck into the dealer and had the computer reflashed. Ever since then, when I turn off the truck, I hear something running for about 30 seconds. Anybody know what this might be?
racinfever is offline
Old 12-19-2006 | 06:20 AM
The Menace's Avatar
Default Re: '05 F350 Diesel Computer Reflash
Fuel pump?
The fuel pump on my 05 runs when the ignition is turned on and the glow plug is heating. However, when turned off nothing runs.
The Menace is offline
Old 12-19-2006 | 08:05 AM
haulinvols's Avatar
www.Bajaboatowners.com
It is your injectors cycling. It is a reflash to improve cold weather starting.
They are supposed to explain this to you before doing the reflash. If they did not, I suggest you call your service manager and ask them why not.
You can find more information here. http://forums.thedieselstop.com/ubbthreads/
haulinvols is offline
Old 12-19-2006 | 02:12 PM
racinfever's Avatar
Thanks for the INFO Mr Vol"s
Old 01-31-2007 | 05:24 AM
actually, the small bowl that holds your fuel filter on top of the engine was not full all the time. so when you used to shut off, there would be a slight lack of fuel pressure and it would take a small bit of extra cranking to start. now your fuel pump runs to fill it to keep the proper pressure up with the injectors and the injectors also cycle to get fuel ready for the re start so the whole system is charged with pressure properly as soon as you turn the key now. my truck runs better and even gets better mileage after the recalls there were 3 recalls on my truck! if you have an o5 get to the dealer, this makes a big difference!
domson is offline
Old 01-31-2007 | 10:48 AM
mwdill's Avatar
did the reflash rob any power?
mwdill is offline
Old 02-05-2007 | 11:06 PM
Joe's Avatar
Joe
Offshore Cowboy
any "updates" needed on the 2006's?
Joe is offline
Old 02-06-2007 | 03:25 AM
DirtyMoney's Avatar
Yes just had an 06 go in for a reflash.
DirtyMoney is offline
Old 02-06-2007 | 08:29 AM
Joe's Avatar
Joe
Offshore Cowboy
What was the issue/upgrade etc.... I'm due for my 30k service and would like to discuss it w/ them while I'm there.
Thanks for the intel,
Joe
Joe is offline
Old 02-06-2007 | 09:43 AM
BajaRunner's Avatar
this is correct. mine was reflashed. its weird.
BajaRunner is offline
