Measurement Needed
Can someone tell me the measurement from the transom to the back of the block or heads on standard Big Block with standard Mercruiser Bell Housing bolted to a standard Bravo transom assembly?
I pulled my engine and now need this dimension for my header tails.
Kirk,
I went out to the garage and took the measurement for you. I am not certain that mine will be exactly the same as yours due to the angle of the transoms most likely be different.
I was trying to find a good constant point for me to measure so you can be exactly in the same spot. I decided that the top center bolt hole that is unused for the bellhousing, the one in the top of the block would be a good place. Besides, I had a clear shot straight to the transom with nothing in the way there.
Mine measured 12" .
Vinny
Mine measured 12" .
Vinny
Charter Member #139 /Moderator/Platinum Member
Kirk,
Are your ok with your dimension question if not I have the boat at the house and will uncover it for you to double check
klaw
klaw
Kept the Bullet and the condo and joined the cig 20 restoration club.
I appreciate it Gary, but not neccessary.
There are a bunch of spoiled Pantera guys and others that have the luxury of boating all year around and they have been shooting me measurements!!
Thanks to everyone!
Thanks to everyone!
Formula Outlaw
05-16-2006 05:16 PM
