Scratched Headers- What can be done? >
Old 12-28-2006 | 09:04 AM
Default Scratched Headers- What can be done?
I have two sets of Stelling headers that over the years have been scratched up. I was thinking of having them coated to a polished aluminum look but I love the bright stainless. Can I send them back to Stellings or can someone else polish them out?
40FlatDeck is offline
Old 12-28-2006 | 11:41 AM
Default Re: Scratched Headers- What can be done?
Do a search on oso this has been covered before, if no luck, there are several polishing companys out there that should be of help.
bobkatz is offline
Old 12-28-2006 | 12:15 PM
BY U BOY's Avatar
Send Them Back To Stellings They Can Polish Them Again.
BY U BOY is offline
Old 12-28-2006 | 12:26 PM
Too Old's Avatar
Stellings can be reached at: (559) 485-9394
Like most marine companies, they are closed until January 2nd
They should be able to make them look new.
Too Old is offline
Old 12-28-2006 | 12:34 PM
KNOT-RIGHT's Avatar
Or save some money and wet sand them with 1000grit
and use some 3m rubbing compound on them with the
Buffer.
Works great just takes time.
Gerry
KNOT-RIGHT is offline
Old 12-28-2006 | 12:56 PM
Thanks guys.
Old 12-28-2006 | 04:00 PM
Depending on how deep the scratches are, use some Mother's Mag Wheel polish and a lot of elbow grease. For deeper scratches, wet sand or use a more agressive compound first.
Griff is offline
Old 01-02-2007 | 05:41 PM
Get some Blue Job ,buy it over the internet or at your local motorcycle shop,it's used to get the blue out of cooked motorcycle pipes,it works great !Add a little water,it works !
MYSKATER32 is offline
Old 01-02-2007 | 10:09 PM
Smitty's Avatar
I would recommend 1200 or 1500. Then use a polish. 1000 grit is a bit rough for my liking.
Smitty is offline
Old 01-03-2007 | 10:36 AM
KNOT-RIGHT's Avatar
If ya look in the Stelling repair manual
it says to start with 1000 then 1200 then 2000 micro fine.
then use 3m 5380 med duty rubbing compound.
Stainless is tough as nails
Not comparible to Chroma clear
