2500 suburban
Old 12-29-2006 | 08:43 AM
Default 2500 suburban
Has anyone installed a rear sway bar on these suv's. If so did it really help?
baja27 is offline
Old 12-29-2006 | 09:20 AM
Sydwayz's Avatar
Forum Regulator
Default Re: 2500 suburban
You want to install four things to improve towing and handling on that truck.
In order:
Putnam XDR Class-V hitch. (Factory hitch is weak crap.)
AirLift 1000 or Firestone Ride-Right Airbags (Instead of a sway bar.)
Rear-wheel spacers (Spread the rear wheels out to the same track as the front wheels, increases stability.)
8" wide wheels (REALLY improve handling and stability)
Byrdman is going to jump all over this thread, but if you have this truck, you have this truck, and that's it.
Check out the Avalanche 2500 thread. Its the same truck, and I put a LOT of info on that thread, all work that I had installed and tested on my 2500 Avalanche.
http://www.offshoreonly.com/forums/s...d.php?t=147175
Sydwayz is offline
Old 12-29-2006 | 12:34 PM
Baja:
The rear sway is not needed. Do what Sydwyz suggested.
Wannabe
wannabe is offline
cigrocket
4
11-24-2005 09:57 PM
westcoaster
11
09-07-2005 08:59 AM
Spent
12
08-09-2005 06:38 PM
Spent
1
08-07-2005 11:50 AM
Madmax
08-05-2002 01:58 AM
