Too much play in sterndrive? >
Old 01-02-2007 | 12:06 PM
StillHaulin@63's Avatar
Default Too much play in sterndrive?
Was out on the water this weekend.
Had a problem with the drive-trim so made the 70-mile run with the drive trimmed down the entire way. Most every time we took a bit of air, the boat seems to loose its stability and began a gentle, but increasing chimewalk. Simply throttling back would restore full control.
After pulling the boat (Baja 272 w 502 EFI) out of the water, noticed "quite a bit" of play in the sterndrive (Bravo/1 w 23p MP). Seemed like about 3-6" of play before the steering wheel would move.
Isn't there an adjustment to tighten up the drive and reduce the amout of "play"?
StillHaulin@63 is offline
Old 01-02-2007 | 12:16 PM
Ted G's Avatar
Default Re: Too much play in sterndrive?
If you get in the boat and look at the transom you will see the strg arm that comes in from the drive. Have someone move the drive and see if the arm moves. If it doesn't then the pivot and arm are worn and will need to be replaced-very common.
www.cbpba.com
Ted G is offline
Old 01-02-2007 | 01:13 PM
Indy's Avatar
Member #154
What happened to your engine problem
Indy is offline
Old 01-02-2007 | 01:38 PM
Still being worked on by Mario (SoCal Speed & Marine).
Went for an island run on my son's (Chrisf) Baja 272 on Saturday.
Old 01-02-2007 | 01:56 PM
RedDog382's Avatar
Also look at the pivot pins where the bell housing rides in the gimble ring. There are bushings that may be worn and need to be replaced.
RedDog382 is offline
Intruder88
10-26-2007 07:57 AM
towhead
09-19-2007 09:38 AM
LubeJobs42
06-02-2003 09:20 PM
RLW
03-06-2003 01:21 PM
FunHome
06-10-2002 11:12 AM
