500 hp specs >
500 hp specs
500 hp specs
Old 01-04-2007 | 04:38 PM
Default 500 hp specs
can anyone give me all the specs of a stock 2000 500 hp carberated.
cam specs
intake runners
cc of heads
valve size
spring pressure
and antyhing else thanks 32 thunder rick
rssteiny is offline
Old 01-05-2007 | 07:48 AM
Michigan Mad Man
Default Re: 500 hp specs
cam specs
intake runners
cc of heads
valve size
spring pressure
It uses the Crane 731 cam it has 320-325 intake runners. The combustion chambers are 118 and they have 2.250 Intake 1.880 Ex valves. They have about 150# seat presure at 1.900.
TylerCrockett is offline
Old 01-05-2007 | 08:16 AM
THANKS TYLER AND ILL BE IN TOUCH ON MY REBUILD
rssteiny is offline
Old 01-05-2007 | 03:13 PM
SB
For Gen VI HP500's cam I have the following in my notes:
Merc HP500 Carb
Crane Gen VI#169611 Grind#HR-284-2S-10IG
Adv 284, 292 at .004” Lift with 1.7 .576 / .598
At .050” 222, 230
ICL 105, ECL 115
LSA 110
Part Number: 169611 Grind Number: HR-284-2S-10 IG
Engine Identification:
Start Yr. End Yr. Make Cyl Description
1996 Up CHEVROLET 8 HYD. ROLLER WITH CAST IRON DISTRIBUTOR DRIVE GEAR
Engine Size Configuration
454-502 C.I. V
Valve Setting: Intake .000 Exhaust .000 HOT
Lift: Intake @Cam 339 @Valve 576 All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 352 @Valve 598
Rocker Arm Ratio 1.70
Cam Timing: TAPPET @.004
Lift: Opens Closes ADV Duration
Intake 33.0 BTDC 71.0 ABDC 284 °
Exhaust 77.0 BBDC 35.0 ATDC 292 °
Spring Requirements: Triple Dual Outer Inner
Part Number 99896
Loads Closed 150 LBS @ 1.900 or 1 29/32
Open 441 LBS @ 1.330
Recommended RPM range with matching components
Minimum RPM 2500
Maximum RPM 6000
Valve Float 6500
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake 6.0 BTDC 36.0 ABDC 105 222 °
Exhaust 50.0 BBDC 0.0 BTDC 115 230 °
Remarks:
CRANE 16535-16 LONG TRAVEL HYDRAULIC ROLLER- LIFTERS MUST BE USED WITH GREATER THAN .570 LIFT CAMSHAFTS TO PREVENT ALIGNMENT BAR DISENGAGEMENT.
SB is offline
Old 01-05-2007 | 11:46 PM
cam specs
intake runners
cc of heads
valve size
spring pressure
rssteiny,
Give Mercury racing a call. 1-920-921-5330 is their prop shop but some one there should be able to hook you up to their engine shop.
Mike
Active Mike is offline
Old 01-07-2007 | 03:46 AM
What TC said except the 500HP cam is the one posted by SB.
Griff is offline
Old 01-07-2007 | 07:27 AM
is this based off a 454 or 502?
awsomethunder is offline
Old 01-07-2007 | 09:31 AM
cuda's Avatar
502
cuda is offline
Old 01-08-2007 | 07:24 AM
BajaRunner's Avatar
what he said, the crane 731 is actually an upgrade in an hp500.
BajaRunner is offline
Old 11-04-2008 | 05:54 PM
What is necessary to upgrade a stock 502 to 500hp specs?
89scarabIII is offline
