Pre Lubers
I installed one last year. It's the canister type that stores oil pressure. Seems to work, once you turn the key, the pressure gauge jumps and there's pressure.
I'm sure the pump ones are a littel better.
I'm using the Eickert kits. Basically a fuel pump that draws from the bottom of the pan. Besides pre lubbing I have a disconnect that allows me to change the oil with the boat in the water.
I had them on my boat and sold them
.Ive never seen any probs from not having them.I just wouldnt rev a cold motor and let the oil pres come up first.Maybe a oil heater in cold climates ,but then its to cold to boat anyway.
I have preluber oil pumps from http://www.pre-luber.com/
I build 40-45 PSI of oil pressure before starting the engines.
Feels good, especially if the engines have been sitting for some time.
The pumps also make oil changes easy.
If the motor isn't turning over you will only be getting oil pressure to a couple journals and not very much up top... That's why you have to manually turn the motor over when you prime it for the first time. The rotating assembly holds most of the oil when the motor is shut down anyway.
I'm no scientist or engine guru but that's my opinion...
I'd say yes but only to a certain extent...
