Twin engine owners with shift/throttle combo
Formula shift close to you, throttles outside.
Originally Posted by jupiter sunsation
On the Sunsations the shifters are on the outside/ throttles closer to you on the inside.
shifter,throttle,throttle,shifter
I always thought having S/S/T/T would be to hard to operate the inside shorter shifters w/o hitting the longer throttle. Having to have both hands in a smaller confined area as opposed to the outside shifter setup looks alkward???
Mine are S/T/T/S. I liked the looks of T/T/S/S, however, in practice the S/T/T/S works very well for the very reason that US1 stated. When docking, the throttles are at idle and you dock with the shifters. It is easy to work the shifters without hitting the throttles when they are on the outside.
