Stellings drive shaft cushion >
Old 01-07-2007 | 08:26 PM
Default Stellings drive shaft cushion
My 382 w/stellings boxes is hard on drives. There is no "drive coupler" on the back of the crank. The short driveshaft bolts directly to the crank. Has anyone designed a "cushioned tube driveline". Any Thoughts??
382 newbie is offline
Old 01-07-2007 | 08:42 PM
Default Re: Stellings drive shaft cushion
Easy solution...Teague stocks a shock absorbing disc that is approximately 1" X 6" that goes between the steel disc from Stellings and the flywheel. Its main use is in high torque applications like diesel powered cruisers. I think they are about $200 ea. You may be able to install it without having to shorten your drive shaft
BenPerfected is offline
Old 01-08-2007 | 07:14 AM
RedDog382's Avatar
The product Sprague is referring to above is the Globe "drivesaver" coupler. I believe there have been previous threads about this. Try a search on drivesaver.
RedDog382 is offline
Old 01-08-2007 | 07:24 AM
Not needed, Teague hasn't sold one in years.
cobra marty is offline
Old 01-08-2007 | 09:38 AM
KAAMA's Avatar
I have Stellings extension boxes on my ride and have used the "Drive Saver" which is like a hard plastic type of material that bolts right on the flywheel coupler. Keep in mind that these Drive Savers will change the angle of your driveshafts because they shorten the length.
I bought mine from Teague Marine about 4-5 years ago----who knows, maybe it was me who was the last to buy them from Teague. I eventually removed the drive savers two years ago---it probably would have been okay, but I didn't like the driveshaft angle. Engines were 540cid Naturally Aspirated 680hp at the time.
KAAMA is offline
Old 01-08-2007 | 03:20 PM
If you decide to move forward, here is the Globe website, they have numerous distributors.
www.globerubberworks.com The part # was MRD504PR.
Old 01-08-2007 | 07:13 PM
I'm glad you took them off!
BGIII is offline
Old 01-09-2007 | 06:11 PM
mcollinstn's Avatar
You can run the Imco torsion shaft with a standard Merc coupler instead of the Stellings shaft/joints/bearing/etc. Drawback is that the box has to be mounted in the neutral position and cant be raised or lowered with the straight shaft.
mcollinstn is offline
FormulaM2Formula
1
02-28-2006 12:50 PM
homan
7
10-11-2004 09:31 PM
Tahoe Scarab
10
10-02-2004 06:46 AM
BILL W
06-17-2003 08:01 AM
Raypanic
5
06-10-2003 11:38 AM
