outdoor storage?
Old 01-11-2007 | 10:44 AM
tblrklakemo's Avatar
SeaRay Sundancer
Default outdoor storage?
I have always prefered indoor storage, but with the mooring cover on Im not too concerned about outside exposure....and I will save some money. Anybody had any serious issues keeping the boat outside in the open?
tblrklakemo is offline
Old 01-11-2007 | 10:57 AM
Iggy's Avatar
Default Re: outdoor storage?
Be sure you have a full cover to keep dirt and debris off it. If it's stored outside in winter snow you'll have to build a wood support system and get it shrink wrapped or use some other cover. Snow will collapse a cockpit or whole boat cover and probably tear it or worse in the process. Also you should jack the trailer up to get the tires off the ground so they don't sink into the ground.
Iggy is offline
Old 01-11-2007 | 11:09 AM
Moisture can create mildew especially where the cover and upholstery come in contact.
Get some wheel covers from an RV shop.
Make sure your cover is secure, or the wind will beat the cover into your paint job.
Make sure stern is lower than bow, so water runs out when it rains.
dave911 is offline
Old 01-11-2007 | 11:23 AM
TSPM's Avatar
Shrink wrap it.................
TSPM is offline
Old 01-11-2007 | 11:42 AM
SeaRay Sundancer
I wonder if the local sea ray boat dealer(they always have shrink wrapped boats sitting around) can shrink wrap it? Or factory only?
Old 01-11-2007 | 12:08 PM
Sydwayz's Avatar
Forum Regulator
Just about anyone can shrink wrap it as long as they know what they are doing. Make sure they don't use too much hear over the cockpit, as it can melt the interior/vinyl. Its also important to have vents installed to not trap in moisture.
Sydwayz is offline
Old 01-11-2007 | 01:00 PM
BY U BOY's Avatar
i would also put some solar vents in the cover to help with midew and gas build up.
BY U BOY is offline
LAKESIDE RESTORATIONS
New Products and Member Discounts
1
09-09-2006 05:51 PM
mwdill
06-27-2006 08:44 PM
epeek
10-06-2005 11:42 AM
t500hps
08-27-2005 05:04 AM
Steve_H
01-02-2004 11:34 AM
